Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 03-12-2002, 06:59 PM
87civwgn 87civwgn is offline
Send a message via AIM to 87civwgn
any tips on possible swap/specs on my motor now?
Hey, I'm new to the board. I drive an 1987 Civic Wagon that was handed down to me. Our original motor blew, and had it rebuilt or replaced like 3 or 4 years ago. It's real old school with a carbeurator and stuff, and I was wondering what the name of my motor was. Also, does anyone know what the cheapest/easiest motor that I can use bolt-on's with is? Thanks a lot, guys.
Watch your back...I've got an army of 76 horses under that hood.
Old 03-12-2002, 07:32 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
swapping a carbureted engine is tough you're gonna have to stick w/ another carbureted engine to avoid a hell of alot of work...check out some of the carb setups the european cars had and see what can be swapped onto a USDM engine...a 88-89 teg engine is a bolt-in affair...
SOLD!
Old 03-12-2002, 11:43 PM
Davidov Speed WRC Davidov Speed WRC is offline
Send a message via AIM to Davidov Speed WRC
I'm pretty sure you have the 1.5 liter EW1 engine(check right above the right headlight for a stamped number on a metal plate, whatever it starts with is your engine number, most likely EW1)
If you are into some heavy work, look into swapping your engine with either the forementioned D16A1(86-89 Integra Motor)
Or the ZC(86-89 JDM Integra Motor)
Which are both bolt-ins, you will need to do MAJOR work to upgrade the fuel systems to support Fuel Injection.
However, for about $500 you can do a Weber Dual Carburetor setup. Which will give you as much power as a ZC engine swap, with less trouble.
It would be sweet to see a Wagon running dual carbs!
Old 03-13-2002, 12:02 PM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
It would be kindof a pain to do carb to fuel injection but i think you would thank yourself after you did it and you will be able to do aftermarket things to the Integra motor(D16A1)....not sure if you wanted to do anything but that would be pretty phat to see a civic wagon with I/H/E and some other stuff.
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
