Old 01-22-2005, 01:25 AM
blazerboy2005 blazerboy2005 is offline
Send a message via AIM to blazerboy2005
charcol canister
is it possible to bypass the charcol canister by runing the line from the gas tank straight to the tbi or is that unsafe sorry for asking a dumb question but i got to know
Old 01-22-2005, 08:09 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: charcol canister
Your Evaporative Emission Control System(EECS) is designed to limit fuel vapors from escaping to the atmosphere. The EECS transfers fuel vapor from the sealed fuel tank to an activated carbon (charcoal) storage device(vapor cannister). The canister will store fuel vapors & fuel condensation until the engine is able to use it.
When the engine is able to use the extra fuel vapor, the fuel vapor is purged from the carbon element by intake air flow and consumed in the normal combustion process. There is nothing gained by bypassing this device.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 01-22-2005, 09:42 AM
i know i just want to get rid of it
Old 01-22-2005, 10:04 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
It also prevents run on and vapor lock... I wouldn't get rid of it..
Old 01-22-2005, 03:35 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: charcol canister
LEAVE it alone.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-22-2005, 03:39 PM
ok then
Old 01-22-2005, 05:36 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
its better to keep it alone but maybe you could swap out the filter in it there only 2 bucks at advance autoparts and only takes 2 days for them to get it in no cost to you for shipping
