Old 01-22-2005, 12:41 AM
blazerboy2005 blazerboy2005 is offline
Send a message via AIM to blazerboy2005
5 min engine cleaner
hi i bought a can of napa fast motor flush 5 min engine cleaner. and i was wondering if it would do a good job cleaning my 89 4.3 240,871mi blazer. please tell my it will help clean out the gunk without ruining my motor
Old 01-22-2005, 07:44 AM
crazys182003's Avatar
crazys182003 crazys182003 is offline
Re: 5 min engine cleaner
the 5 min flush also needs to be run through your vehicle. I have used it numerous times and had no problems. It does a pretty decent job. I had flooded my vehicle and when I did an oil change I used the flush. The flush went in clear and came out black. also brought a lot of dirt and debris with it out.
Old 01-22-2005, 08:33 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
I ran Gunk 5 min. engine flush through a severely neglected & sludged up 267 V8 in a '79 Malibu I traded for following the directions EXACTLY and putting fresh oil and filter after the flush. It's a thin solvent and I worried about the bearings but loosened up alot of junk and 1 oil & filter change a week for 3 weeks finally cleaned up the motor with no damage.
On a motor with roller lifters, I wouldn't use it because of all the junk it loosens quickly. I believe 3 or 4 1000 mile oil & filter changes would accomplish the same thing and not overload the oil filter to the point of bypassing the junk back to the oil system.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 01-22-2005, 09:18 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Seafoam..
Old 01-22-2005, 09:34 AM
thanx guys sounds good ill have to try it
Old 01-22-2005, 03:39 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: 5 min engine cleaner
Just throw it in the warm oil and idle it for 30 minutes and dump your oil and replace with a fresh oil filter and oil.
Sometime, it is smart to swap in another cheap oil filter when you are running the flush just to catch all the crap coming out. Then install another oil filter with the fresh oil.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-22-2005, 03:44 PM
it says only to run it for 5 min thgen drain
Old 01-22-2005, 03:50 PM
yes but I am sure that the can also says to drain your oil first than add. Blazer LT said to run 30 mins becaue he adds to the oil before he even drains anything. the can assumes that it will be the only thign in your system.
Old 01-22-2005, 03:53 PM
nope the can says add to youre oil that is allready in and run for 5 min
BlazerLT's Avatar
AF -Advisor
NO!!!!!!
You don't EVER run a cleaner without oil!
COMMON SENSE!
Old 01-22-2005, 03:54 PM
BlazerLT's Avatar
AF -Advisor
Run it through for 30 with it only at idle.
Might as well swap on a cheap oil filter while you are doing it to catch all the crap it will be dislodging and cleaning.
no crap
Old 01-22-2005, 03:56 PM
but it says only 5 min it wont hurt it to run for 30
Old 01-22-2005, 03:58 PM
BlazerLT's Avatar
AF -Advisor
Trust me on this ok.
Put it in and idle for 30 minutes, it will not hurt anything at all, and keep it ONLY at idle.
Old 01-22-2005, 03:59 PM
will it plug up my oil pump screen its got a lot of crap in it
