Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-22-2005, 12:20 AM
jsweeter jsweeter is offline
not starting
I have a Dodge ramcharger 4wd 318 cid. The truck will not start, it has been at times running like it is misfiring only at idle. Sometimes it will die and i will have to hold down the accelerator a little to get it started again , but if i let off the gas it will die. The engine when you go to turn it off it diesels. Now it wont start at all. I Bought the car from a friend and he replaced the carb. with an older style, so i just replaced the distributor and ign. coil. It had a tune up this past summer. Can someone help me?
Old 01-22-2005, 09:13 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: not starting
Sounds like it's been flooding and now the spark plugs are gasoline fouled. Try new spark plugs & get the choke set so it'll quit flooding the motor. This will require a real carburetor expert if you want to solve your problem...check with your local raceshop for a good carb. man.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 01-22-2005, 11:31 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: not starting
Maybe the catalytic converter has plugged.
My Mopars
Old 01-22-2005, 01:17 PM
the carb has a electric choke does that matter at all
Old 01-22-2005, 01:19 PM
Re: not starting
it has been flooding, would that cause it to die
Old 01-22-2005, 01:30 PM
Re: not starting
could it possibly be a timing chain?
Old 01-22-2005, 03:42 PM
Re: not starting
it was spark plugs , i changed them and it started right up , i have a friend that races at a local track ill get him to help w/ carb , thanks a lot
