Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-21-2005, 08:47 PM
sandrasimpson sandrasimpson is offline
1997 Ford Explorer XLT V8 EGR VAlve
Is there a tool to remove and replace the egr valve or do you have to remove the whole engine or take it to the dealership? My check engine message is replace egr valve but I can't get to it. Help!
Old 01-22-2005, 06:17 PM
FordTech4U FordTech4U is offline
Re: 1997 Ford Explorer XLT V8 EGR VAlve
There is not an exact tool to replace the egr valve you're referring to on your 5.0L explorer, but ive found a crows foot socket to be most useful in the tight quarters, just out of curiousity, what trouble code do you have, its possible that you have an egr code and the valve is not at fault, let me know.
Old 01-22-2005, 11:34 PM
Re: Re: 1997 Ford Explorer XLT V8 EGR VAlve
The code reads that the egr valve is bad. But a mechanic told me that it might not be that, that maybe I could clean out around the housing in front of it because it might not be getting good vacumn?
Old 01-24-2005, 11:27 AM
brokesilverado's Avatar
brokesilverado brokesilverado is offline
do you know what the code numbers are
Old 01-27-2005, 08:50 AM
jvsnowden jvsnowden is offline
You have to remove the upper intake manifold to replace the EGR valve. Most repair shops will quote 6-8 hours. I did it in about 3 hours. If you do this make sure you mark your vacum lines and be careful not to break any lines.
Old 01-27-2005, 09:04 AM
what year of explorer did you do that too
Old 01-27-2005, 09:08 AM
my valve is driverside front of motor as you are looking at the wind shield it has 1 vacume line on top and two hard lines with metal fittings on them the sensor is located on the drivers side valve cover mine is a 99 4.0L sohc
