Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-21-2005, 08:41 PM
tjgala tjgala is offline
1997 Dodge Ram Front End Thumping
After putting new rancho shocks and new tires on truck, I took it it for an alignment, and to check out front end. One guy put on new bushings on sway bar, and said all was ok . Next guy did alignment and changed a u-joint, and said that was all he could see nothing wrong. Now I notice (it may have been there before, but now I hear it cuz I also had some exhaust work done, and my truck is quieter) a dull clunking while city driving, sounds/feels like its coming from directly under drivers feet. Rancho says to make sure shocks are tightened to 100 ft/lbs, but I checked and all bolts are as tight as I can get em. Ant ideas? Could it be from the cold weather?
Old 01-21-2005, 10:07 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 1997 Dodge Ram Front End Thumping
Definitely could be because of cold weather.
My Mopars
Old 01-21-2005, 11:16 PM
Blastin Turkeys Blastin Turkeys is offline
Check your wheel bearings and your Axle shaft Cardan u-joint
Replacing mine tomorrow after going through what you went through!
both were bad on mine after 130k
