Old 01-21-2005, 07:52 PM
dj140civic dj140civic is offline
Question speedometer cable
ok so i replaced the alternater in my car tha other day and i could not get it out through the bottom or the top so i went behind and under the throttle body and all of that stuff but i accidentlyy pull out my speedometer cable and now i don't know how fast i am going what could be wrong i put it back in the hole where it was and nothing help meeeee
Old 01-21-2005, 08:29 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
make sure that the cable wasnt pulled from behind the cluster too...try jiggling the cable where it goes in the tranny and make sure it's secured w/a clip...or try driving without the cluster for a couple of blocks and see if the cable actually turns when you drive...
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 01-22-2005, 12:17 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Re: speedometer cable
There is a little notch that has to go into a slot in the tranny. If that doesn't go in, it won't work. I just replaced my speedo cable the other day.
Take a flashlight and look down the little tube that goes into the tranny and find out where the slot it, then line up the notch on the cable to that slot, and it should slip right in.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 01-24-2005, 12:36 AM
thanks guys
