Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-21-2005, 07:14 PM
smith476 smith476 is offline
1998 Dodge Ram pickup
I hear a clicking noise when turning. Could that be the limited slip differential.
Old 01-30-2006, 06:14 PM
shogun88888888 shogun88888888 is offline
Re: 1998 Dodge Ram pickup
Possibly, sounds like you might have a lock-right or detroit rocker installed in the differential case. They are traction modifications. Did you buy your truck used or are you the only owner.
Old 01-30-2006, 06:20 PM
P.S. If you do have a locker modification installed. The clicking is normal
Old 01-31-2006, 02:52 AM
rontomed's Avatar
rontomed rontomed is offline
I had the same problem with my 99 Ram. I tracked it down to a heat shield next to the passenger side exaulst manifold that was tapping the suspension during left turns after a front brake job. A slight bend toward the exaulst manifold silenced the heat shield.
Old 01-31-2006, 10:17 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
if you have an aftermarket dif, then the clicking is normal, assumeing that it's coming from the rear axle. if your truck has the factory limited slip, it should NOT make noise.
try to track down exactly where the "clicking" is coming from, if you have a 4x4, and the noise is coming from the front, it could be a U-joint starting to go out.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 01-31-2006, 11:09 AM
yeah what he said, try to find out where the clicking sound is coming from and exactly when it does it and does not do it. eg. moving, stopped, turning, etc.
