Old 01-21-2005, 04:45 PM
s14240sx s14240sx is offline
Tail Lights
I have a 89 f250. anyone know why and how to fix this problem. I have no Tail lights..brake,turn, head lights all work but no tail lights.
Or if anyone has a FSM for a 89 f250.....thanks
Old 01-21-2005, 10:35 PM
mustangmike351c mustangmike351c is offline
lights
do you have dash lights?
Old 01-22-2005, 08:50 AM
DDeBoer's Avatar
DDeBoer DDeBoer is offline
Re: Tail Lights
Check your brake light switch located above the brake pedal.
1985 F250 HD 4X4 7.5L DUALLY
SUPERCAB W/GOOSE NECK FLATBED
EDELBROCK PERFORMER #1406 CARB
EDELBROCK PERFORMER 460 INTAKE
FLOWMASTER DUAL EXHAUST W/4 INCH STACKS
Old 01-23-2005, 12:22 AM
all lights work but the tail lights
Old 01-23-2005, 12:23 AM
Re: lights
Where exactly... do you have an pic?
Old 01-23-2005, 12:27 PM
DDeBoer's Avatar
Re: Tail Lights
The brake light switch is located on the brake pedal arm about 9" above the brake pedal. The plunger from the switch extends when the brake pedal is pushed thus completing the circuit and turning on you brake lights. Their is 2 wires connected to this switch and should be the only switch attached to the brake pedal assembly under the dash.
Old 01-23-2005, 12:29 PM
Re: Re: Tail Lights
I have brake lights just not tail lights
Old 01-23-2005, 10:47 PM
ModMech's Avatar
ModMech ModMech is offline
Re: Tail Lights
Hmm, an '89...
For memory here, there should be a connector under the master cylinder that runs down to the left frame rail, check for power to one pin with the parking lights on, and see if it goes dead with them off. If that's ok, move to the connector next to the fuel pump on the left inner frame rail under the driver's seat. If there move the the connector at the REAR of the rear tank (if equipped), and check for voltage (battery -0.5Vdc), if ok someone probabally installed a trailer light wiring kit and wrecked the wires near the bumper/left frame. You can patch if necessary, but a rear harness from a wreck would be a much better option.
Old 01-24-2005, 12:10 AM
Re: Tail Lights
tow package was installed at one time but wires all cut
