Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 01-21-2005, 04:24 PM
Robbyc30 Robbyc30 is offline
XM radio thru changer input on CD?
Hi guys!
I spent the better part of today searching the internet for some info on this, but came up with nothing. I'm trying to find out if it's possible to hardwire a satellite receiver, to the CD changer input on a USA SPEC CD player, that I added to my wife's 1999 Honda CRV factory head unit. The CD player connects into the head unit with a 14pin plug. There is also an 8pin input on the CD player, meant for a changer. I also have a cable that I can attatch to the 8pin jack. This is what I'd connect the XM receiver to. However, I have no idea if it would even work without some kind of interface unit. Also, I can't find any pinout info on the CD player, so I can't identify the 8 wires. Just trying to get as much info as I can before I spend an entire day outside in the 20 degree weather with my toolbox and voltmeter, tearing apart her car and trying to trial-and-error it. Thanks in advance for any help.
Rob
Old 01-21-2005, 04:30 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: XM radio thru changer input on CD?
Which XM reciver do you have?
What you are looking for is a blitz-safe connector, I have one in my TL-S. Its connects to the CD changer port in the back of the stock head unit. In my case I have an XM Commander and it also feeds power to it as well. I had to run 0 wires, only the antenna. It is not cheap though.
Here is the link to it.
Old 01-21-2005, 04:47 PM
That was quick! Thanks. Unfortunately, I don't think that will work. The harnss for the 1999's uses the 14 pin plug on the back of the radio. I'm using that for the CD player. The plug I'd need to use is from the CD player, and is an 8pin plug. They have those, but not for the 1999's. Oh, I haven't purchased a sat receiver yet.
Rob
Old 01-21-2005, 04:58 PM
whtteg's Avatar
So you have a CD player and a radio both seperate in the dash?
How about a CD changer, do you have one?
I am a little lost on what you are saying, I am not real familiar with the accords.
Old 01-21-2005, 05:15 PM
It's not an Accord, its a CRV. It has a factory radio/cassette as the head unit. I added the USA SPEC CD player, connected via the 14pin cable. The interface for the 1999's connects via the same 14pin plug. The CD player has an 8pin plug intended for an additional changer. They do have an 8pin interface, but it's for the wrong year(92-98). I sent them an email asking if I could use the 8pin interface with my setup.
Old 01-22-2005, 11:55 AM
whtteg's Avatar
Re: Re: XM radio thru changer input on CD?
Gotcha
Hopefully they will tell you that it will work. If you can get the setup for the Commander, it is so easy to install when you use that harness. Good luck.
Old 01-22-2005, 10:28 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
other suggestion i would do, is probe for the signal wires, and setup a switch so you can switch between the two sources.. there are also wire sets for the setup you want to do..
check these out..
http://www.autotoys.com/x/catalog/OE...e_1_c_101.html
hope it helps.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 01-23-2005, 03:49 AM
Thanks so much for the great suggestions. Hopefully one of them will work. I still may try to figure the pinout so I can use the cable I already have, rather than spend more money on a new one. Thanks again!
Rob
Old 01-24-2005, 02:54 PM
Just thought I'd follow up. I got an email from Blitzsafe saying the way I wanted to setup my system would not work with their interface. I also sent an email to Auto Toys, but haven't heard back yet. In the meantime, I guess I'll try to figure the pinout.
Thanks again,
Rob
Old 01-26-2005, 06:23 PM
Another update. Auto Toys said they didn't know if their's would work either, but that I could try it. Oh, and all sales are final. Great! Thanks! If I get around to the pinout, I'll make sure to post it here.
Rob
Old 01-27-2005, 06:42 AM
tell me again which XM reciever do you have?
Old 01-27-2005, 01:52 PM
The wife just bought a SkyFi2. Does it really matter? Shouldn't the audio output be the same, regardless of the reciever?
Rob
