Old 01-21-2005, 04:01 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
instrument cluster removal questions
im going to put in a new head light switch, also while im at it im going to put in all new lights cause the gas, oil and voltage guage light bulbs are blown. i know to remove the dash pad, pop the bezel off from around the guages, then remove the screws from around the cluster and pull it out.
now to my ?, after removing the screws from around the guage cluster, do they just slide out. ('90 RS) or does my car have the speedo cable?
see i removed my bro's guage cluster from his trans am (86) and it was a breeze, nothing to disconnect just remove the screws and slide it out of the dash. im hoping thats all i need to do.
Old 01-21-2005, 05:49 PM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
Re: instrument cluster removal questions
yeah thats all you need to do.. Everything is electronic, so you can pull the whole cluster out.. Steering wheel has to be all the way down, and usually you gotta play with it a little bit..
1991 Camaro Z28
Old 01-21-2005, 05:59 PM
Re: Re: instrument cluster removal questions
what a relief. im getting her closer to perfect. im in need of some good black armrests.
Old 01-21-2005, 06:15 PM
DaMoNe6969's Avatar
my little bro just picked some up from a wrecker for $5 bucks.. theyre mint..
1991 Camaro Z28
Old 01-21-2005, 06:16 PM
cool. mine i think just need reglued. they are flipped up around were they go against the door panel.
Old 01-21-2005, 06:31 PM
DaMoNe6969's Avatar
Isnt it just vinyl over foam?? Not really anything to glue too.. You could try gluing it, and bolting it back to the door to hold it in place
1991 Camaro Z28
Old 01-21-2005, 06:36 PM
yeah im going to try it, cause they look like hell right now. i had a set of perfect ones for a 86 camaro and my bro gave them away.
Old 01-22-2005, 12:03 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Tacoma, I wrote up a somewhat detailed explanation of removing the gauge cluster a few weeks back, here's a link if it helps...
http://www.thirdgen.org/techbb2/show...hreadid=272447
Old 01-22-2005, 02:00 AM
those guages are bad ass.
