Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Engine
Engine intakes, exhaust, turbos, nitrous.
Old 03-12-2002, 03:04 PM
Blue93G20 Blue93G20 is offline
Question JWT S3 Cams
Who has them and who likes them....
What do all of you think of them. What goes into replaceing the stock ones with them, is it a straight wap or do i need to replace other things in order to put them in (i.e. shims and such). Also is the engine idle bad with these or is it streetable without too much headache.
Last question is will i pass emissions with these?
93.5 Infiniti G20
JDM SR20DE
Lowered on Intrax, Hotshot Header and Hotshot CAI
15.90@88MPH
http://community.webshots.com/album/34345621pASGoo
Old 03-12-2002, 10:16 PM
paradyme paradyme is offline
Thumbs up
I have them in my 95 G20t. You should change your tensioner, unless you have a brand new car. They have a mild lope that is hardly noticeable. They add noticeable performance improvement (Your car will redline faster). They cost me $560.00 from STILLEN. I also ungraded my ECU. I have never had any trouble with them, they were installed a little over a year ago. The JWT S3 cam and ecu I highly recommend.
:flash:
paradyme
95'G20t/AUTO/BLK
STILLEN HEADER/INTAKE/JWT/ECU/S3 CAMS/P11 99 G20 RIMS/
VIPER SECURITY/w/ REMOTE START/ ALPINE AUDIO
Old 03-12-2002, 10:20 PM
NismoP10 NismoP10 is offline
Re: JWT S3 Cams
I have them on my 96P10 (low port motor). They work really well but on low port motors, a little bit of torque is lost. On high port motors, which I believe you have, the totally kick ass! They are a straight swap (SR20s don't have shims). I would go ahead and replace all the valve cover gaskets and clean the oiling tubes when doing the swap since "you're in there anyway". The engine idle isn't bad at all w/ the cams, however, I would recommend getting a JWT ECU w/ the S3 program to make the best use of the cams. I've passed California emisssions w/ the JWT S3 cams and ecu and a POP charger.
Gil
96 P10 w/ stuff
Old 03-14-2002, 08:22 AM
240ztt's Avatar
240ztt 240ztt is offline
Re: JWT S3 Cams
What hp/torque increase did you guys get after adding both?
Joe aka 240ztt
'71 240Z HLS3020425
'79 810 KHLG810000299
'94 XE P/U 1N6SD11S6RC345206
'03 XTerra SE/SC 5N1MD28Y73C697225
'03 Honda Insight JHMZE14793T000067
*nothing but Nissans in my garage*
*so what If I have a Hybrid*
Old 03-25-2002, 01:54 AM
how much was it for the ECU upgrade???
93.5 Infiniti G20
JDM SR20DE
15.90@88MPH
