Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-21-2005, 12:42 PM
Volkswagon Volkswagon is offline
99 pass port fuel pump problem
I replaced just my fuel sender, which fixed my gas gauge problem.
Now, the fuel pump does not make the 3 second wirr sound to prime the system when the engines hot.
When the engines cools, no problem. It starts right up and you could drinve to Alaska, just don't shut off the engine!
what the heak is wrong?
Old 01-21-2005, 01:16 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: 99 pass port fuel pump problem
loose connection
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-21-2005, 01:42 PM
steveb_92rodeo steveb_92rodeo is offline
I firmly believe that Amigo is right...
My Rodeo had this exact problem (with others too). For a couple days, I ran the fuel pump direct to battery (switched) and the problem did not reappear.
I then ran a new wire (with an inline fuse) directly from the relay to the fuel pump. Ran a new ground directly to the frame and I haven't had any starting issues since. That was about a month ago.
We have had -35c weather the past week, and still, starts and runs great.
I'd start by running the pump direct to the battery and I'll bet your problems will dissapear. (Make sure you fuse the wire though, I *think* it's 10A).
Steve
Old 01-21-2005, 01:59 PM
Thats what I want to do, check for power and then run a new fused wire to it. I'll check it out over the weekend. And I have to say the response was very quick, this is amazing.
One question though, when you ran that new wire from the relay, do you still get the 3-5 second fuel pump prime sound or is it constantly on?
Does that make a difference? Why does it have to prime it up and then stop? Is that for safty reasons?
Old 01-21-2005, 02:11 PM
Re: Re: 99 pass port fuel pump problem
I honestly didn't check. It just works. I know for fact though, that when it was from the battery, it was on full time.
I'm not to worried whether it shuts itself off after 3-5 seconds anyway...my 'zu is running by then ;o)
Seriously though, as far as I know, the pump is not variable, so no matter what state the engine is (high RPM, load, no load etc), the pump operates at the same speed anyway, so I figure no damage can happen.
The only reason I ran it off the original relay was so it would at least half-ways be the way it was, and I'd safely be able to use the ignition trigger to fire the pump properly.
It works, so it stays. I do stress again though, to use a good wire and a fuse.
I actually ripped off the back of the under-hood fuse box and brought the wire out of there. The fuse is outside the box, in a proper sealed fuse container so I can get at it easily.
Since I didn't know the exact path the original wire took, I though this was the easiest solution.
Best of luck, I was near ready to drop the tank and pull the pump.
Steve
Old 01-21-2005, 02:21 PM
How long has it been runnig like that?
Old 01-21-2005, 02:26 PM
Just shy of a month now. Absolutely no problems whatsoever since.
I was so happy, I looked at everything before that, because everytime I put the fuel pressure tester to it, it worked. I didn't consider a loose connection at that point.
It was so frustrating, but things are much better now!
Steve
Old 01-21-2005, 02:32 PM
I'll let you know. Thanks
Old 01-22-2005, 05:09 PM
Pump still quits
Old 01-24-2005, 08:08 AM
Pump still quits
Time to drop the tank. It's either wiring inside the tank, or the pump itself has gone bad.
Steve
Old 01-24-2005, 08:17 AM
yes when I directly ran a 12 volt line to it, it ran for a while then stops. After a while, it will run again, intermitently
Old 01-24-2005, 08:26 AM
I'm sorry to hear that. I was hoping it would be an easy/quick fix like mine (mind you it took me quite a while to find it out).
Good luck...let me know when you find out exactly what the problem is.
Steve
Old 01-24-2005, 08:33 AM
St charles said maybe I have to have the ecu reset whenever replacing the fuel sender (which I replace) It worked for a while, then the fuel pump started acting up. I don't think resetting the ecu won't do anything since I ran a hot wire directly to it and got the said problems.
Old 01-24-2005, 08:36 AM
I have read on many forums that some vehicles need the reset after a sending unit replacement.
Now, that said, the pump should run all the time if wired direct, however, the injectors are controlled by the computer. Are you certain it's the pump cutting out and not the injectors? Have you tried putting a pressure guage on the fuel line?
Old 01-24-2005, 02:35 PM
But a hotwire to the fuel pump will energize it right?
In regards to fuel pressure, I don't have a fuil pressure gauge, but whenerver I press the fitting on the fuil rail, the gas squirts with very high pressure, so there is definite gas at the injectors.
