Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-21-2005, 07:55 AM
Boyka Boyka is offline
4 wheel drive won't lock up
4 wheel drive won't lock up,the transfer case will engauge but 4 wheel drive won't work. There was a vaccum line that was broken from the front axle to the tranny which i fixed but still doesn't work . Before it stopped working it would take a long time to engauge and when i disengauge it would unlock very hard.
Does any body have any thoughts to this problem, Is it maybe a sensor
Old 01-21-2005, 09:06 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 4 wheel drive won't lock up
Your profile says 99 1500; right?
OK so the vacuum wasn't working too well initially, then quit entirely. I'd suspect the vacuum system for the front axle, and check there first. Make sure the hoses are in good condition, don't have any kinks or flat spots, and are connected properly. Trace the system back all the way from the axle to where it terminates.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-21-2005, 10:14 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
there is a shift fork in the axle that could be jamming up due to a number of things.could be a vacume prob or a prob with the fork itself. hows fluid in axle? if you take off cover you can check for metal pieces for a true diognosis. won't hurt to change fluid anyways!!!
Old 01-21-2005, 10:21 AM
Re: Re: 4 wheel drive won't lock up
[quote=fredjacksonsan]Your profile says 99 1500; right?
OK so the vacuum wasn't working too well initially, then quit entirely. I'd suspect the vacuum system for the front axle, and check there first. Make sure the hoses are in good condition, don't have any kinks or flat spots, and are connected properly. Trace the system back all the way from the axle to where it terminates.[/QUOTE
Thanks for your reply Fred.
I do believe that it is a wiring problem off the sensor on the axle going back into the main wiring harness . I have went though it with an o meter to find no voltage ,Vaccum lines seem to be fine, I will let you know and thanks for your time.
Dale
Old 01-21-2005, 10:35 AM
Re: Re: Re: 4 wheel drive won't lock up
Dale
So no voltage to the actuator, hmmmm might be a problem there. Mudder does have a point though, so opening it up would be a good idea.
Old 01-21-2005, 02:02 PM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
all the wiring dose is turn on the light on the dash, even if there is a problem with the wiring, it will have no effect on the locking and unlocking of the CAD unit.
go here, http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
there is a diagram of how the CAD (central axle disconnect) unit should be hooked up, and how it works.
hope this helps ya out some,
Keith
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 01-21-2005, 02:58 PM
Keith, great resource thanks. I done been edumacated.
Old 01-21-2005, 06:58 PM
Re: Re: Re: Re: 4 wheel drive won't lock up
I thank you guy's for your help , I did pull the cover off and the forks and interal parts are fine. So what i did was locked up the interal gears and put it back together , very temporary but it did stay in gauged . The 4x4 light doesn't come on so on i'am guessing that maybe the actuator itself . As there is lots of vaccum out of the black line going into the housing and the housing canister seems fine . But one question i do have this canister doesn't act like a one way valve does it ? For some reason i think it is the actuator sensor but it most certainly isn't interal.
Like i said thanks alot guy's and if you have any other ideas . I will be sure to let you know the out come .
Dale
Old 01-21-2005, 07:05 PM
Keith
Thanks Keith , I'm printing out this link you sent as it should help solve this delema .
Thank you .
Dale
Old 01-21-2005, 08:44 PM
After reading on the link that ScoutinKeith sent, it may be the actuator, since those go bad often.....
Old 01-28-2005, 05:17 PM
Talking Re: Re: 4 wheel drive won't lock up
4x4 not locking up,problem solved
Hey Guy's
To Fred , Keith , Mudder
Once again i would like to take the time to thank you gentlemen . I thought it's only proper to let you guys know what the problem was .The Vaccum control motor was finished as the only thing i can think the diafram must have a hole or a crack in it . There for wasn't locking up the front end.
Thanks
Dale
Old 01-28-2005, 11:19 PM
2000mudder's Avatar
glad you found prob. i'll check that first if mine stops working!
