Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-21-2005, 06:28 AM
Daci Daci is offline
Send a message via MSN to Daci
Coil Problem?
I installed a Accel ignition coil and at high RPM the engine cuts off. I replace it with a new one but it does the same. What might be the problem?
Old 01-21-2005, 10:16 AM
ridered ridered is offline
Re: Coil Problem?
at what RPM is it cutting out at?? does it have a rev. limiter built into it???
just a thought
Old 01-21-2005, 11:08 AM
Re: Coil Problem?
Depends. The hotter it gets it cutts off at lower RPM. It got to a point that it started to cut off at 1900-2000RPM. I dont think it has a rev limitter
Old 01-21-2005, 09:43 PM
Re: Coil Problem?
are you running stock wires?? maybe they need an upgrade if the Accel is a hotter coil ?
Old 01-24-2005, 06:51 AM
Re: Coil Problem?
I have 8mm Accel wiresand Accel distribuitor cap anr rotor
