Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-21-2005, 01:53 AM
valdesp03 valdesp03 is offline
injector fuse blows
I have a 97 sc2 that blows injector fuse in high RPMs. the prob does not happen when in neutral just when in a gear.
Old 01-21-2005, 01:30 PM
carguy83 carguy83 is offline
Send a message via AIM to carguy83
Re: injector fuse blows
dumb question... are you using the correct amperage?
1995 Gold Saturn SL2 -- RIP May 05
1991 Blue Subaru Legacy Wagon -- RIP Aug 05
1995 White Mazda 626 DX -- RIP Feb 07
1991 Black Volkswagen Jetta Carat -- Current
Old 01-21-2005, 01:43 PM
i am using the right amperage.
Old 01-22-2005, 12:48 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
do you have a multimeter and/or an ocsiloscope ( i doubt i spelled that right)
or a fuel pressure tester?
Old 01-23-2005, 11:46 PM
Re: Re: injector fuse blows
No i do not
Old 01-25-2005, 11:25 PM
well i would use a multimeter to check the resistance of the injectiors, and check system voltage. an ocsiloscope to check pluse width and the flyback voltage spike. and the fuel pressure tester because if fuel pressure was to low, the PCM might energize the injectiors to long, but that is a long shot.
if you could find someone with a multimeter, i would start there.
