Old 01-21-2005, 02:21 AM
markallen's Avatar
markallen markallen is offline
Angry car turns over but dosent start help!!!!!!!!!!!!!!!
i have a 96 camaro z28, one night i drove my car home worked perfectly fine the night before didn't act up or stutter, the next morning when i went outside to start my car it will turn over but won't start, i can hear the fuel pump going but the car wont fire up, i removed the fuel cap and saw dirt around it i'm not sure if this is normal being that i live in cali "no offence" or was this foul play?
Old 01-21-2005, 06:04 PM
Krypt0's Avatar
Krypt0 Krypt0 is offline
Re: car turns over but dosent start help!!!!!!!!!!!!!!!
Hmmm. I would get under your car and remove the tank side of your fuel line from your fuel filter, crank it and see what comes out. If it wasn't foul play and she's pumping good I would start looking in your ignition system. Specifically the ignition module. Do you have a spark checker?
1992 Camaro RS - 5.0L 305 V8
Flowmaster Exhaust, K&N Filter, Redline Water Wetter
Hypertech 160 Powerstat w/ 177-166 Fan Switch
245/50/16 Kuhmo Tires on 16" ASA Wheels
JVC KD300 CD/MP3 Player
Old 01-21-2005, 06:37 PM
markallen's Avatar
Thumbs up Re: Re: car turns over but dosent start help!!!!!!!!!!!!!!!
thanks for the tip!!!! it turns out to be some sort of spark problem there is no spark going to the plugs and this did happen after a couple days of raining if that has anything to do with it, i'm still stumped and how to solve it, i would appreciate all the tips and help i can get
Old 01-23-2005, 03:58 PM
Krypt0's Avatar
My camaro is a 3rd generation. Not up on the 4th gens. Does your car have a regular distributor and external ignition coil? 9 times out of 10 when you don't have spark its the ignition module. (which mine is mounted on the distributor itself). Check and make sure all your spark plug wires are tight at both ends. I would grab you a $20 chilton book for your model. It will give you the steps to test your ignition system. Hopefully a few 4 Gen owners will chime in and help.
Good Luck!!
Old 01-30-2005, 10:40 AM
86TA 86TA is offline
Send a message via AIM to 86TA
ive got a 95 V6, and the same thing happened, all it was on mine is that the coil packs were going out..., take them off and inspect them, see if they are coroded and such...
Old 01-31-2005, 02:46 AM
markallen's Avatar
thanks for all the help it turns out to be the ignition module
Old 01-31-2005, 06:38 PM
Krypt0's Avatar
Am I good or what?
Old 02-01-2005, 02:40 AM
y2icon's Avatar
y2icon y2icon is offline
Send a message via AIM to y2icon Send a message via Yahoo to y2icon
woot congrats so its working fine again. after i get my vats fixed ill have to check that out too
Nitrous= the car equivalent of a penis pump
