Old 01-21-2005, 12:22 AM
KBL91 KBL91 is offline
fuel injector?
Thank you in advance for your help. My problem started out with a bad fuel leak out of one of my injectors. Jeep ran great before i started(but the leak). Replaced O-rings. Now no leak. Jeep runs like crap. Think its running ritch, black smoke out the tail pipe. what did i do damage an injector? Are the o-rings on the bottom leaking?
Old 01-21-2005, 06:52 AM
ops5 ops5 is offline
Send a message via Yahoo to ops5
Is it idling rough along with the black smoke? could be the map sensor if so. Maybe it got disconnected. Or, maybe you did in fact damage something...maybe some others have some ideas
1991 Cherokee Sport
4.0L HO
AW4
Old 01-21-2005, 09:12 AM
Ironic Ironic is offline
Re: fuel injector?
Sounds like a bad injector. Disconnect the electrical connector 1 at a time while its running, if you disconnect the bad 1 it won't make any change to the idle- good 1's will. Is it possible you mixed up the electrical connectors?
Old 02-05-2005, 05:16 PM
speedycat's Avatar
speedycat speedycat is offline
Re: fuel injector?
This also happened the first time we replaced the o-rings. Found a broken tube(vac?)that runs behind valve cover, replaced it and all was fine. Hope this helps.
Speedycat :
