Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 01-20-2005, 11:41 PM
BP_Weber BP_Weber is offline
Question 98 Jetta GLX VR6
Several issue:
1: "Check Engine Light" came on, dealership said it was an emissions code error, would have to lift up manifold to start determining the problem, 3 hrs just to do that. Is the dealership b/sing me?
2: Windows will no longer go up or down when I put the key into the drivers side door and turn it.
3: Can arm the alarm w/ the remote, light on drivers door does not come on. Put key in door, car door unlocks, but if you open the door the alarm goes off.
Old 01-21-2005, 02:59 PM
boschmann boschmann is offline
Re: 98 Jetta GLX VR6
See if you can get the engine trouble code number. The second two are probably from the same problem; the driver's door lock sensor switch is not working in the unlock position. You'll need to go inside the door to check out the problem.
Old 01-21-2005, 03:14 PM
Re: Re: 98 Jetta GLX VR6
Engine trouble code number: PO411
Old 01-22-2005, 02:54 PM
That code is for incorrect flow detected at the secondary air injection pump. In fron of the engine you will see a plastic pump motor with a few rubber hoses and a plastic pipe that goes over to the air filter housing. Check the pressure hose that goes around to the exhaust side & the smaller vacuum lines that go to the valve/solenoid. If they're okay the problem is either the pump motor or the valve/solenoid has failed.
Old 01-22-2005, 02:57 PM
The dealership is telling me. 2 -3 hrs of troubleshooting time 1st. Then after that, may have to lift the manifold. At that point they will be able to get to the vacuum lines. Am I being BS'ed?
Old 01-22-2005, 04:00 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Ha... there arent any vacuum hoses inder the manifold. at least ones that you cant reach without taking the manifold off. Check the fuse for the secondary air pump (on firewall under plastic clear cap) THey usually blow. (its a40amp metal bar with 2 screws on both sides) Plus a vw dealer only charges 1hr diag for check lights)
Old 01-24-2005, 05:25 PM
OK, the light went back out yesterday. Has not come back on... Should I wait to see if it comes back on or is this something that could leave me dead on the side of the road?
Old 01-26-2005, 10:15 PM
VDUBMAN
The only real thing emissions related that would cause you extreemly bad drivability probs is a bad MAF sensor (600$) but since your car isnt running that bad right now i would say just pop the hood and check for any cracked vacuum hoses or look for oil residue on the intake pipe by the intake throttle body (the pcv portion of the intake pipe breaks spits some oil arround it and you have to replace the entire intake pipe.)
Old 02-05-2005, 03:36 AM
Accord Type R Accord Type R is offline
Send a message via AIM to Accord Type R
i agree
click here to join trendforce!
Old 02-05-2005, 11:34 AM
It ended up being the vacuum lines, parts cost under $10. They charged me $250 in labor...
