Old 01-20-2005, 09:56 PM
mann1961 mann1961 is offline
Injector work interminttently
t happen again at around 190 degree temp. I try and switch the wire on the injector that was not working, and it worked, so my injectors are good. When this happen I had a chance to slightly tap on the ECM and it stop. Ok now does this mean i need a new ECM or just a bad connection. Your help is greatly appreciated.
Old 01-21-2005, 07:53 AM
rpreston rpreston is offline
Re: Injector work interminttently
If tapping the ECM fixs the problem, try reseating the connectors and the chip. If it comes back I'd replace the ECM.
[SIZE=3]"How do you feel about Women's rights?" " I like either side of them."[/size] - Groucho Marx
Old 01-21-2005, 10:08 AM
Fireplug Fireplug is offline
replace your ecm ,seen a lot of ecm problems like that
Old 01-22-2005, 01:04 PM
skipr skipr is offline
Isn't it called a VCM now? the ECM is the older terminology but they are the same thing, actually now they have a PCM as well.
Old 01-22-2005, 03:56 PM
it depends what year it is you have ECM, VCM PCM,PCM b ,PCM c, just to name a few also you have BCM , TCM Tccm, and so on
