Go Back   Automotive Forums Car Chat > Racing > Drag Racing
Old 01-20-2005, 09:47 PM
smokin' joe smokin' joe is offline
Banned
Help!!!!!!!!!!
hey whats up im just starting in this sport im 16 and i drive a 1970 mustang with a 351 cleavland and it has
bored 30 over
balanced and blue printed
polished crank
flat top pistons
shot peened rods
lunati 520 lift cam
weiand intake
ported and polished heads
roller rockers
hooker headers
weiand water pump
electronic fuel pump
mallory electronic ignition
750cfm holly
3200 stall converter
3:55 spooled
and some other stuff like line lok (FUN FUN)
any other suggestions please send
P.S it runs 12.40
Old 01-27-2005, 11:44 AM
AWP9521 AWP9521 is offline
Re: Help!!!!!!!!!!
Not a bad ride for starting out. I raced a 79 Mustang for 5 years (Man I miss racing!) Here is the specs
351 Windsor Bored .030 over
Stock reground Crank
Magnafluxed and Shot Peened Stock Rods
Dish Top Pistons
Comp Cams .519/.523 lift 274/286 duration Hyd. Cam
Edelbrock Victor Jr. Intake
Holley 700 Double Pumper
Ported and polished Heads with 1.94/1.60 Manley Valves, Screw in Rocker Studs and Guide Plates Trick Flow Hardened Push Rods and Harland Sharp Roller Rockers
Dynomax Headers
Stock Water Pump
Holley Mechanical Fuel Pump
MSD Ignition with a home made 2-Step Box With 6400 RPM limiter chip and a bypassable Variable Staging RPM adjustment (4500 RPM limited in bypass mode)
Modified C-4 Tranny with Reverse Manual Valve Body and Trans Brake, 3800-4000 Stall Converter
9" Rear End with 3.89 gears and Detroit Locker, 31 Spline Axles
Car is completely gutted except both front seats and all the glass, 6 Point Roll Cage installed, 5 Point Harness, and subframes tied together. Battery, Tranny Cooler and Fan, and Fuel Cell reside in the Hatchback
Best times and speeds; 60 Foot ET 1.548; 1/8 mi ET 7.369; 1/8 mi Traps 90.732; 1/4 mi ET 11.849; 1/4 mi Traps 113.340
Old 02-08-2005, 02:16 PM
ASTAutoSales ASTAutoSales is offline
Banned
Re: Help!!!!!!!!!!
Ok.... Nice Car now what do you need HELP!!!!!!!! with?
Old 02-09-2005, 08:47 PM
Banned
Re: Re: Help!!!!!!!!!!
Ok I need HELP!!!!!!!! with adding more power but still keeping it streetable.
Old 02-09-2005, 09:08 PM
chevytrucks92's Avatar
chevytrucks92 chevytrucks92 is offline
Re: Help!!!!!!!!!!
Port the intake to match the heads and go with bigger valves.
**1966 Chevy II**
355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4
Last Race (10-6-07) So its been awhile...
Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph
Fastest Pass of '07 (10-6-07)
60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph
25 and in BIG TIME Debt Crew member #2
Deuce's Wild Racing: Take a Ride on the WILD SIDE
Old 02-09-2005, 09:34 PM
Banned
THAT MIGHT ALREADY BE HANDELD I WILL HAVE TO CHECK
Old 02-09-2005, 10:27 PM
benchtest benchtest is offline
Re: Help!!!!!!!!!!
Which heads? 4V, 2V, open chamber, closed chamber? (I'd expect 4V, but you never know) What compression? Hydraulic, solid or roller cam? Flow specs? Using port-plates? Street or strip-only? (Dump the spool for street use) Which rods? Which block? Sounds like a nice car. Any pics?
Remember: Don't confuse noise with horsepower! and Junk is junk, even when it's on sale!
"I would never doubt your expertise....it's obvious you wrote the book on stupidity!" DD
Old 02-10-2005, 10:20 AM
500 500 is offline
Re: Help!!!!!!!!!!
Has Ford ever made a stout overdrive automatic ? With GM you can use the 700 which allows you to use a 4.11 or 4.56 on street and still have a nice tall cruising gear. 4.56 X .7 [ I think that's the 700 ratio ]OD = 3.19 .
Fiberglass hood. Seal the hoodscoop to the airfilter. K&N 4" tall filter.
500
Old 02-10-2005, 12:13 PM
Re: Help!!!!!!!!!!
All Ford has is the AOD, they can be built for racing but that goes beyond just installing a shift kit, the internals have to be modified too. I hear they even make them where you can manually shift 1-2-3 with the shifter then flip a switch for OD as well as getting high stall converters for them either with or without lockup.
Old 02-16-2005, 08:19 AM
Banned
500
it already has a fiberglass hood with hoodscoope. and i dont whant that big of an air filter and for trans. the ford AODE is a ok one that is what are 1996 mustang gt had in it
Old 02-16-2005, 01:54 PM
Broncodriver Broncodriver is offline
Re: Help!!!!!!!!!!
For best racing, the C6 auto tranny is probably the best ford makes. It doesnt have OD but who cares. It is still streetable as well, matter of fact that mustang probably already has the c6. So stay with that tranny, they can be built to handle massive HP. Sounds like a nice car, btw.
"If you can walk to the welfare office, then you can walk to work." -- Al Capone
Old 02-16-2005, 03:01 PM
Banned
my car already has a c-4 with a 3200 stall and shift kit
Old 02-16-2005, 08:20 PM
Re: Re: Re: Help!!!!!!!!!!
You're just going to have to go bigger valves and cam then. That will hurt your streetability, but that's just the price you'll have to pay if you want to go faster.
Either do that or put the car on a diet.
**1966 Chevy II**
