Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 01-20-2005, 08:43 PM
DM_Rok DM_Rok is offline
Manual tranny pops out of gear
I have a 91 2wd p/u with 170k. The transmission pops out of 1st unless I hold it in, and wont even stay engaged in 3rd when I release the clutch. However, 5th gear operation is ok, as well as the other gears. I am about due for a clutch and would like to tackle this issue while I have the tranny off. Any suggestions as to what it could be, or what to inspect for a probable cause? I am a bit stumped since, like most mechanics, I am more familiar with the internals of automatic trannys since manuals hardly ever break, LOL.
Old 01-21-2005, 11:01 AM
galbin galbin is offline
Re: Manual tranny pops out of gear
OK Rok I have a similar problem with my 4X4 and I had someone at capital toyota look into the linkage part of the manuel transmission and there are some plastic pieces in there and when they ge worn out from shifting .... this can happen
Old 01-22-2005, 03:29 AM
Vip09 Vip09 is offline
Send a message via AIM to Vip09
I had the same problem with my '91 4x4.. it would pop right out of 1st unless you held it in.
Best GT-S STOCK times: 1/4: 14.788 @ 94.98mph 1/8: 9.640 @ 75.87mph
Best Alltrac times: 1/4: 13.3 @ 102mph (older setup) 1/8th: 7.8 @ 83mph (old setup)
Old 01-29-2005, 10:18 PM
Re: Re: Manual tranny pops out of gear
Thanks for the tip.
Are those plastic pieces part of the shifter mechanism or are they located inside the trans. case?
Old 02-13-2005, 01:22 AM
importrazcer importrazcer is offline
hey heres a link to help you out, parts should be in stock @ dealer for about $10 http://www.off-road.com/toyota/tech/shifter/index.html
Old 02-21-2005, 12:55 AM
AzNkEviN87 AzNkEviN87 is offline
Send a message via AIM to AzNkEviN87
hey, i also have the same problem but with my 3rd and 4th gear on my 92 Toyota pickup 2wd, so all i need is a new shift lever seat & bushings?
Old 02-21-2005, 06:48 PM
thats it, and a little greese between the shifter ball and seat. i choose to remove to shifter housing (4 bolts) to avoid getting bits of the crumbled seat into the tranny.
Old 03-02-2005, 11:13 PM
canifitit canifitit is offline
Unhappy
I am having the same problem! It wont stay in any gear unless i hold it in. If it does popout and I try to put it back in it also makes a grinding noise some times. Is the replacement something that can be done by somone with pretty much no knowledge?
Old 06-23-2005, 11:57 AM
WayCool WayCool is offline
wont stay in gear
Hi All .. First post here... looks like a great place with good information and help !!
Anyway.. I have an 89 Toyota 4x4 ext cab pickup with a 22re. This is a GREAT truck and I am new to Toyota.. I also have a 02 Duramax for pulling a horse trailer around... etc.....
I primarily use the Toyota for hunting and off road stuff... its in great shape and I would expect it has had an engine replaced and maybe tranny too.. as it has 224,000 miles on the odometer but runs like it was brand new.. and the previous owner (second owner) documented ALL repairs in three repair manuals he had...
Anyway.. I have stated to notice this issue.. If I'm a low RPM it will fall out of third gear .. if RPMs are up no problem staying in gear.. occassionaly 4th will do this also...
I have called the Toyota dealer and they have the seat and bushing in stock so I will give that a try.. is there anything else I should look for ?? And does anyone know if I must remove the carpet to remove the shift lever ??
thanks for any help ! And I really do dig this little truck !
--Steve
Las Cruces, NM
Old 02-15-2006, 09:29 PM
buddjl buddjl is offline
Question Re: Manual tranny pops out of gear
So, I was having the exact same problem and I went to purchase these parts, pulled out the shifter, removed all the peices of the old seat, put in a new one, changed the bushing, put everything back together...
And it still does the EXACT same thing. Any clue what could be wrong?
How does this seat cause this problem?
Old 02-26-2006, 09:13 AM
SidneyCanada SidneyCanada is offline
Replace pilot shift lever bushing & seat:
Shift lever pilot bushing # 33548-31010 (green)=$7 CDN
Shift lever seat # 33505-35020 or 33505-35030 (white)=$16 CDN
Note: the 2 above #’s fit all trannies:G,R,W series (22R,R-E,3VZE)84-95.5,no need for entire shift lever retainer (85-95.5 pre-Tacoma)
http://www.4runners.org/articles/shift
http://www.marlincrawler.com/docs/sh...eat/index.html
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:[email protected]
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 247 000 KM
http://groups.google.com/group/hfx.f...4c696fbf04837f
http://www.iwaynet.net/~nesda/May02/May18.html
http://www.iwaynet.net/~nesda/SonyAudMod.html
http://www.newark.com/product-detail...ge/32-9495.jpg
http://www.tipsmaster.ca/hottips-1.HTM
http://www.tipsmaster.ca/1011-TV32C50-007.jpg
http://www.iwaynet.net/~nesda/June03/June0315.html
http://www.iwaynet.net/~nesda/Apr03/Apr033.html
Old 07-06-2006, 03:47 AM
metafizx metafizx is offline
Hi,
Having the exact problem on my 2WD, 125K mi. Hard to get into 2nd, 3rd, and 4th. Pops out of 3rd and 4th (they are the worst).
22RE '94 Pickup.
Can anyone confirm their fix ??
thanks in advance !!
Old 07-14-2006, 10:42 PM
thank you very much for the useful info.
I replaced the shift lever seat and solved the problem with it popping out of gear. the hardest thing was getting the damn shift boot and plate back in !!
btw this is the part number I used : 33505-35020 and got it from drivetrain.com
Old 09-16-2007, 03:31 PM
axekick's Avatar
axekick axekick is offline
I replaced those parts and he shifter feels better, but it still pops out of first. I'll be car shopping this weekend. I'll replace the tranny when I have some free time.
