Old 01-20-2005, 08:12 PM
Uncle Jed Uncle Jed is offline
Help - 02 suburban keyless entry
I would appreciate any suggestions anyone might have. Keyless entry (both FOBs)quit working about 3 months ago. Replaced the batteries - attempted to reprogram - changed the fuse - still nothing. When attempting to reprogram held lock and unlock buttons down but got no response (no cycling of locks, etc). Anyone have any ideas? Where on the vehicle does it receive the signal from the remote? That is the only place I can think to check but don't know where it is. Once again, any help would be appreciated.
Old 01-20-2005, 09:29 PM
TaNK_Em's Avatar
TaNK_Em TaNK_Em is offline
Send a message via AIM to TaNK_Em Send a message via MSN to TaNK_Em Send a message via Yahoo to TaNK_Em
Re: Help - 02 suburban keyless entry
Is this a factory or aftermarket keyless entry?
- Kevin
May God have mercy upon my enemies, because I won't.
- General George Patton Jr
Old 01-21-2005, 11:54 AM
factory
Old 01-21-2005, 12:17 PM
TaNK_Em's Avatar
Sorry I dont really know a lot about these keyless entrys, Was just browsing around and found this http://auto.howstuffworks.com/power-door-lock1.htm i dont know take a look see if it has anything. Check the owners manual for any troubleshooting stuff.
- Kevin
Old 02-14-2005, 12:40 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Holding down the LOCK and UNLOCK buttons on each remote for 7 seconds after changing the batteries should sync them back to the vehicle.
If that doesn't work, here is the 02+ programming procedure:
All transmitters which are to be recognized by the PDM must be programmed in a single programming sequence. When using this program method, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter.
The order in which the transmitters are programmed will determine its numbering position within the PDM memory. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number stamped on the transmitter case is for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available.
1. Close all the vehicle doors.
2. Insert the ignition key into the ignition lock cylinder.
3. Press and hold the door unlock switch.
4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
7. Repeat the previous step to program up to four transmitters.
8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
9. Operate the transmitter functions in order to verify correct system operation.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
