Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-20-2005, 05:37 PM
rmiller87109 rmiller87109 is offline
1994 Ram 1500 5.2L won't start when warm
I have a '94 5.2L that starts fine when cold and runs great. However, when if I shut it down when it's warm, it will turn over but not start again until it cools all the way down. Any clues where to start?
Old 01-21-2005, 09:53 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 1994 Ram 1500 5.2L won't start when warm
Couple things....if the fuel line is up against something hot, it could be vapor locking. Uncommon, but possible.
More common would be the Hall sensor in the ignition. These sometimes go bad. There's a thread in here where that is addressed.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 01-21-2005, 03:50 PM
If it's vapor lock, would it need to cool down all the way (couple of hours) before it would start? The hall sensor might be a possiblility...would it run fine with a bad hall sensor? The pickup runs great once its started...no problem, no check engine light. It just turns over and won't fire until it's cool again once you shut it down.
Old 01-21-2005, 08:37 PM
True enough; odd problem for sure. Vapor lock/fuel line would take awhile to ease off to where you could start it. Maybe there's a sensor that shows the wrong value if it's warm, keeping the computer from "doing the right thing" to start?
Old 01-25-2005, 05:52 PM
Just for the sake of checking, I checked the spark. NO SPARK when trying to start when warm, but the spark is fine when running warm. Would the Crank Position Sensor do this?
Old 01-25-2005, 09:17 PM
It could be; I'm not sure. But check this forum for references to the coil, sounds like something I read there.
