Old 01-20-2005, 03:26 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Removing Headunit
I have a 94 Camaro and I am trying to remove the trim around the head unit how do you do this? Also I am going to be running my amp wire under the door trim does this just simply pop out? Thanks
White 07 STI, Bone stock for now
Old 01-21-2005, 06:55 AM
Biggsj84 Biggsj84 is offline
Re: Removing Headunit
assuming its the same as mine (which it should be, mines a 96) the trim around the headunit has 3 screws on each side holding it in. They run along the inside of the glove compartment and under the piece of trim beneith the steering wheel. As for the door trim, its just held on with 3-4 screws, and pops of pretty easily
Old 01-22-2005, 10:02 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Pull.............hard.
Old 01-24-2005, 02:31 PM
chevy_chic20041 chevy_chic20041 is offline
Send a message via Yahoo to chevy_chic20041
Re: Re: Removing Headunit
yeah he's right,i have a 95 and i've run the amp wire and replaced the head unit and thats exactly how it was done....its fairly easy to do
Old 01-25-2005, 11:08 PM
superducky55 superducky55 is offline
i can vouch for that too. the panel beneath the steering wheel and the 3 in the glovebox and she pops right off.
then the headunit is mounted behind the trim w/2 screws, clearly visible
