Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-20-2005, 03:06 PM
the1hiphop the1hiphop is offline
Question 1g or 2g throttle
Is it true that a first gen. gsx throttle is better then a second gen. gsx throttle, and if so does it bolt right on or due you have to change some things. thanks
Old 01-20-2005, 05:19 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: 1g or 2g throttle
Yes, all 1st gen turbo throttle bodies are better than 2nd gen turbo throttle bodies. They have a bigger opening. 91-94 will work fine in all 2nd gen turbo eclipses, you just need to swap out the TPS (throttle position sensor).
Old 01-21-2005, 10:24 AM
kjewer1 kjewer1 is offline
AF - Advisor
60mm vs 52mm if anyone wants the sizes. Bolt patter is the same. But the opening in the 2g manifold is 52mm, so that has to be enlarged or the 60mm TB doesnt help much.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
