Old 01-20-2005, 02:25 PM
Otakon1983's Avatar
Otakon1983 Otakon1983 is offline
Send a message via Yahoo to Otakon1983
Question 1991 Engine Noise
I have 2 1991 Geo metros. One of them has 200k on it and the other has 89k on it. they both make the same noise. It quiets after it warms up but is still noticeable. It sounds like the noise is on the top side. It almost sounds like a knocking rod but the noise doesn't get any worse. Therefore I have ruled out a rod, rods get worse. It sounds like lifter noise. I was wanting to know how to get rid of the lifter noise without having to tear down the engine.
Also, does anyone know if they make an overdrive auto for the metros?
If it Jams, Force It, If it Breaks, It needed Replacement Anyway.
If it jams force it, if it breaks it needed replacement anyway!
Old 01-21-2005, 10:01 AM
geozukigti geozukigti is offline
Metros by nature have noisy lifters. What weight oil are you using?
Old 01-21-2005, 02:17 PM
Otakon1983's Avatar
I am running Valvoline 20w 50 with lucas oil stabilazer. The Stabalizer quiets it down quite a bit. However it is still noisy.
Old 01-21-2005, 02:24 PM
capritoms's Avatar
capritoms capritoms is offline
Wow...I always thought that was a I am running 10w40 in my 96 with 160K on it. There is some lifter noise but I would be afraid to go that thick. I wonder what would be correct?
Old 01-21-2005, 02:27 PM
Otakon1983's Avatar
I have ran 20w in my metro before and had no prob's. The only thing that I can tell is that mine lost a mile per gallon, 49 instead of 50. But of course that's not really enough to call it a loss.
If It Jams, Force It, If It Breaks, It needed Replacing Anyway.
Old 01-21-2005, 02:30 PM
Otakon1983's Avatar
The proper oil weight for the G10 and G13 is 5w20.
If It Jams, Force It, If It Breaks, It Needed Replacing Anyway.
Old 01-21-2005, 02:37 PM
capritoms's Avatar
Re: 1991 Engine Noise
I think I'll be safe with what I run as long as I keep oil in it
Old 01-21-2005, 04:58 PM
I'd go with 10w30 at the heaviest!! Your engine head is running dry! That's why it's making noise. Your camshaft is gonna get worn down, and your lifters aren't properly adjusting. I bet even when it's warm, when you get off the freeway, it ticks for a minute from all the high RPM's.
Old 01-21-2005, 07:30 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
i have torn several geos apart that sounded like they had a noisy lifter and they all turned out to have cracked piston skirts
