Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 01-20-2005, 01:01 PM
Jess&Greg Jess&Greg is offline
Wierd rattle noise behind idler pulley
We have a 2000 saturn sc1 and for the last couple of days we have been hearing a wierd rattle noise on the passenger side of the vehicle. So we took of the tire and looked and found where the noise is coming from but we were wondering what it is called. It's the little plastic thing behind the idler pulley? Is it something to do with the tensioner. Just wondering so we can get it fixed. Thanks.
Old 01-20-2005, 08:24 PM
DM_Rok DM_Rok is offline
Sounds like that wasn't the Idler pulley you are describing. The Idler Pulley is located on the top center of the Timing cover. The Belt Tensioner is located beneath the Power Steering pump and has a plastic pivot. When the tensioner goes bad, it makes a rattling type noise like the one you described. I would start with replacing the tensioner, since the Idler pulley makes more of a "groaning" type sound when it goes bad.
Old 01-21-2005, 12:12 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Wierd rattle noise behind idler pulley
check link -> http://www.saturnfans.com/photos/sho...hp/photo/8177/
idler or tensioner?
Old 01-21-2005, 07:09 PM
If you look at the picture on the link that sierra has on here, it is the tensioner pulley. The actual rattle noise is coming from the plastic pivot piece. So what do I actually have to purchase and replace. The pivot piece or is that included with the tensioner pulley? This is my first saturn. Not a pro yet. Thanks for the info. I sure do appreciate it.
Old 01-22-2005, 01:07 AM
to the best of my knowage the tensioner is sold as an assmbily
http://www.saturnfans.com/forums/showthread.php?t=24989
Old 01-24-2005, 08:26 AM
Sierra is right, The tensioner assy. needs to be replaced. 2 10mm bolts hold it in if you are planning on replacing it yourself
