Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 01-20-2005, 12:28 PM
sm413043 sm413043 is offline
Send a message via Yahoo to sm413043
one more about the 89 bronco
after the truck is warm, the truck idles fine, but when i put it in gear, it boggs almost to a stall. redid timing, new plugs....problem still there...HELP.
Old 01-21-2005, 03:27 PM
Psychopete Psychopete is offline
Re: one more about the 89 bronco
What engine is in your B2? I would scan the codes, and see if you have an air fuel mixture problem. When I was installing MAF on my 1988 Ranger 2.9L, the configuation differences from the 3.8L MAF and my stock injectors caused it to run lean as crap. MY Ranger would bog down, almost stall when I put it into gear. Luckily I bought an IST air adjuster and I was able to run it richer. You might have a catastrophic transmission failure though.
Just a thought,
Pete
Old 01-21-2005, 06:28 PM
Re: Re: one more about the 89 bronco
it is a 2.9 and i will give it a try as soon as i fix the tranny..p.s., what would u recommend a Fort Wayne Clutch and Driveline clutch kit or a oe clutch kit, and what else should i buy if i buy the kit?
