Old 01-20-2005, 10:03 AM
tdag tdag is offline
battery drain
1982 camaro 305 battery keeps draining. Once I jump it, it's ok., when I park it for the night i have to jump it in the morning. Can anyone tell me how to test for a drain on the electrical system. thanks
Old 01-20-2005, 11:27 AM
chevy_chic20041 chevy_chic20041 is offline
Send a message via Yahoo to chevy_chic20041
Re: battery drain
have u had the alternator tested??
Old 01-20-2005, 08:01 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: battery drain
youre trying to test for a paracitic draw on the system. basicly you have to hook a multimeter in parralell to the negative battery cable. then disconnect the cable from the battery so that the drain is going through the multimeter. Make sure the car has been sitting for a while and the meter has dropped to its lowest setting. Say for instance when you first hook it up and disconnect the cable, it will read 150 milliamps, when it drops to 8 milliamps you know youre fine. if it only drops to say 40 milliamps, you know you have a draw. go to the fuse block and start pulling fuses one at a time. when you pull a fuse and the draw drops you know thats the problem circuit and you need to find the short.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
