Old 01-20-2005, 09:58 AM
bcrsqwe bcrsqwe is offline
ABS Light
Can someone please advise ... Brought my 1999 Windstar to the dealer since the ABS light went on. They said it's the right front sensor ... they wanted $300 to replace it so I took the car back and bought the sensor myself for $32 and replaced it myself... it seemed simple enough but I don't understand why the ABS is still on after I replaced it. Is there computer codes to reset and if so, can it be done w/o bringing it back to the dealer.... THANK YOU IN ADVANCE.
Old 01-22-2005, 05:08 PM
hvse06 hvse06 is offline
Re: ABS Light
on my '96 'star, if my brake fluid is a little low, the abs light comes on. A little fluid added, and it's off. In fact, I did that this morning. One time, I had a hairline crack in the right front caliper (saw it as a moist line, while changing pads), and I replaced it. I still don't know where the fluid goes. I mean, as your pads wear, the level goes down, but it seems to leave the resevoir at a much higher rate.
I hope that helps a bit.
Old 01-22-2005, 09:32 PM
brick wall brick wall is offline
The light may also come on if your shoes/pads are worn out and require replacement.
Old 01-23-2005, 06:36 PM
wiswind wiswind is offline
Re: ABS Light
On my '96, the fluid just needs to be a hair off the full indicator on the resevor......and the light comes on. Also, there is a sensor in the master cylinder that can go bad....as I have read on this forum.
