Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 01-20-2005, 09:13 AM
oreo2004 oreo2004 is offline
95 Jetta car alarm problems
I just got a 95 Jetta, and every time I go to stick the key in the ignition, the car alarm goes off...any ideas of what to do? Please let me know! Thanks
Old 01-20-2005, 03:03 PM
boschmann boschmann is offline
Re: 95 Jetta car alarm problems
Do you want to try to keep the system or disable it?
Old 01-20-2005, 04:10 PM
Re: Re: 95 Jetta car alarm problems
Either way...I'd like to keep it if at all possible, but if not, I can do without it...
Old 01-21-2005, 02:50 PM
Can you turn the alarm off by turning the key in the driver's door to unlock? Does the alarm seem to set properly when you lock the door? The more common problems are with the lock switch & the wiring between the door & body right at the hinges.
Old 01-22-2005, 01:22 PM
smiley herbert smiley herbert is offline
Hi, I have a problem with alarm also. (94 Jetta) and would like to just get rid of the problem! How can I disconnect it without disabling the car?
Old 01-22-2005, 02:42 PM
There are about 5 recent threads outlining it in this forum.
Old 03-05-2005, 09:40 AM
danoco7x24 danoco7x24 is offline
I would like to disable the system, could you talk me thru it?
Old 03-06-2005, 04:44 PM
The module is located above the driver's feet, behind the knee panel. It has two connectors, one 6-pin and one 10-pin. Dicsconnect the module & remove. In order to keep the starter functional you must take the red & red/black wires from pin #5 & #6 of the 6-pin connector & connect them to each other.
Old 03-07-2005, 05:28 PM
zeek1403 zeek1403 is offline
I have a 1996 Jetta and the alarm system is weird. It only goes off when I use the key to open the trunk if the doors aren't unlocked. How is the system supposed to work as in how it can be set off?
Old 03-14-2005, 08:29 PM
kole kole is offline
I have jetta III gl 95 and I want to disable alarm
too.Can somebody give me details what should I look for?How those moduls look like?Do they have
some numbers or letters on them?I found some moduls in that area plugged in.But I dont know
which one is for alarm.
Thank you
Old 03-15-2005, 04:12 PM
Find the one with the two connectors outlined above.
Old 04-15-2005, 08:12 AM
myronf myronf is offline
It could be that the wire core in one of the 2 wires for the trunk lock micro switch has broken. The switch moves every time the lock is cycled. The truck lid liner can be removed after taking off the plastic retainer clips. After removing the liner, you will be able to get to the lock assy.and the micro switch. The wire insulation will probably look ok, but it could be the wire core or even the micro switch itself has failed. When these wires do break, it will be too close to the switch to be repairble. VW has reinforced the wires on the replacement micro switch. With the liner removed, it would be worth the effort to check the remote trunk release linkage. The sheathing for the linkage can bunch up and jam the linkage. Good luck Zeek. I hope this helps.
Old 02-02-2006, 04:48 PM
kaiscape kaiscape is offline
Thanks a ton bosch. I disconnected the battery on my '97 Jetta to perform some repairs. Upon reconnecting the battery the alarm would go off and I was unable to turn it off due to two broken door handle locks. Needless to say the car wouldn't start with the alarm going off. After reading your post I went lookin' under the knee panel. I disabled the module as u described and connected the 5 and 6 wires. Worked like a charm. Thanks again!
Old 05-02-2008, 05:57 PM
jonwong524 jonwong524 is offline
how do you pull wires 5 and 6 from the plastic module? I'm having trouble with that
Old 11-01-2011, 04:05 PM
Broyld_08 Broyld_08 is offline
I have a 1995 VW Jetta, the car alarm keeps going off which is killing the battery but before this it would die while i was driving then id have to wait 10-15 mins, any thought on what it is? how much in repairs, roughly?
