Go Back   Automotive Forums Car Chat > Suzuki > Samurai
Old 01-20-2005, 09:28 AM
lovett1200 lovett1200 is offline
shifter only sticks sometimes
I have just purchased an 88 samaura, but the 5 speed shifter hangs up every 5th or 6th time I drive it around the farm. When it works, it shifts just fine, then it will hang in neutral, it will move side to side, but won't go into any gear. I just replaced the little shifter bolt yesterday, but still same problem. Any body have this problem? Any ideas? Thanks.
Old 02-09-2005, 04:14 PM
smarquez1 smarquez1 is offline
Re: shifter only sticks sometimes
Sounds like you need a new shift sheet--just a nylon washer type thing that flops down under the shifter and keeps it in line and the bottom unable to flop under or out of place. They are on eBay (look under 'Samurai Suzuki shifter') for under ten bucks.
Sinner
98 Isuzu Rodeo 2 wheel drive/manual
86 Suzuki Samurai
78 K5 Blazer, 6" lift
66 Chevelle
Old 01-24-2006, 09:12 PM
samuraijack samuraijack is offline
No, shifter sheet is for the T-case, not the Tranny. I have the same problem, seems to happen only during cold weather. It may be to high of a viscosity in the gear oil I am using, just a guess though. I would think if it was the clutch, it would happen more consistantly.
Old 02-07-2006, 11:49 AM
PJRaces11 PJRaces11 is offline
no wrong they have it for both the one for the transfer case is called a T-sheet and when it goes out it will hang up in netural the shifter will do the same thing it is called a shifter sheet and a website called rocky-road.com has the sheet you can look for the number and give them a call or order it offline they will know what you are talking about when you call them to order it very great site let me know if this helps they arent too much money either
PJ
