Old 01-20-2005, 08:01 AM
Leesmack Leesmack is offline
ECU codes??? 1 flash??
i checked my cars and it flashed once which says it is a oxygen content problem. exactly what would that mean??
Midwest Meet in Saint Louis this Spring 2005!!!!
1st Midwest Meet
90 honda civic hb 4 spd manual
short throw shifter
ngk platnium plugs and wires
castro synthetic oil
Old 01-20-2005, 08:06 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: ECU codes??? 1 flash??
You may need a new O2 (oxygen) sensor. Bosch makes universal single wire O2 sensor for cheap or you can go to dealer and spend lots of money if you want OEM.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 01-20-2005, 09:22 AM
honduhcivic honduhcivic is offline
if you have a aftermarket header and had to lengthen the wire, check your wiring again. If not its probably your o2 sensor going bad. Try to reset your ECU and see if it comes back.
Anti-rice leader #001
I <3 my b16
Old 01-20-2005, 02:50 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
does it blink once then stop? or does it repeat 1 blink... pause... 1 blink... pause... etc.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-20-2005, 03:04 PM
just one flash. i sit there and watch it for a while and it does just one flash
1st Midwest Meet
short throw shifter
Old 01-21-2005, 03:40 AM
yeah is probably your o2 just going bad. also check the plug where it clicks into your wiring harness, they can get realy dirty and grimy sometimes and that could possibly be causing it.
I <3 my b16
Old 01-21-2005, 01:29 PM
Instead of starting a whole new thread... somebody mentioned to check the wiring from the O2 sensor to the ECU. Based on this ECU pinout pic from the manual here can somebody tell me if it's in fact C157 to C16 to the ECU (C16 is the very last plug hole right?) I have a one blinker but my car runs fine... (replaced O2 sensor and reset)... thanks.
2010 Honda CR-V EX
Old 01-21-2005, 04:58 PM
that one single flash (not doing 1, pause, 1, pause) is just showing that the ecu is getting power. Its supposed to do the one flash as soon as you turn the key, nothing to worry about.
ZC stuff
Old 01-21-2005, 05:16 PM
are you sure?? if so thanks for telling me and god bless..
1st Midwest Meet
short throw shifter
Old 01-21-2005, 05:25 PM
100% positive
ZC stuff
Old 01-21-2005, 05:33 PM
88ReX 88ReX is offline
Originally Posted by 91civichatch2571
100% positive
He's right
"us FartoX guys are intelligent, excellent drivers who would never stoop to levels of pure testosterone"~Earlsfat
