Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 01-20-2005, 05:53 AM
BriLit BriLit is offline
Outer door handle replacement?
Hello,
Has anyone ever replaced an outer door handle? I took the door panel off yesterday to inspect it and it looks impossible. I can not even get my hand up in there to touch the bolts. I did get all the way down to removing the "rust" colored plate behind the panel, but that is as far as I could get. The reason I have to is the door will not open from the outside.
It is a 97, I am working on the passanger side. Any help would be greatly appreciated.
Old 01-22-2005, 10:01 AM
Re: Outer door handle replacement?
Originally Posted by BriLit
Hello,
I am starting to worry that it's not a DIY job. Can anyone post the shop manual steps, or steer me in the direction to get the right steps?
Old 01-22-2005, 05:21 PM
serick04 serick04 is offline
I have never had a classic Aurora door taken apart but most cars require the removal of the door glass to get any kind of access to these parts. Removing door glass in a classic Aurora is relatively easy though.
Old 04-19-2005, 06:32 PM
Well.
Now the other side front outer door handle will not open. I have been inside there three times (ran out of time), and still can not see how to get the handles off. I have removed one of the bolts that holds one side of the handle, but that's as far as I got.
Has anyone had any experience removing the outer door handles, or does anyone know where to find the procedure? I am willing to pay some fee, since the dealer wants $240.00 for the labor to do both.
Thanks.
Brian
Old 04-21-2005, 09:21 PM
vamc's Avatar
vamc vamc is offline
I guess you could go to the dealership and they can print off how to get to it, but if you dont want to go that way, you could get a cheltons(sp) book. the book may tell you how to get to it. i hope this helps. If anybody has a different idea, please help me out or help back up my answer.
Old 04-22-2005, 12:22 AM
ckpaas ckpaas is offline
Re: Re: Outer door handle replacement?
I did it. My drivers side handle broke the nub part off that trips the latch. I broke it trying to open a frozen door. They wanted an ungodly amount for a new handle and to paint it. I took the nub and drilled through it the put a screw and some glue on it. It won't last forever but i'll be more gentle with it now. You can do it.
Old 04-22-2005, 04:56 PM
Re: Re: Re: Outer door handle replacement?
Soooooo.....how did you get it out?
Old 04-23-2005, 12:04 AM
Re: Re: Re: Re: Outer door handle replacement?
Well, I remeber 2 screws that I used a long extension to get at. After I losened up the handle assy. I worked it out of the socket as far as I could then pushed the pin that holds the handle part out and that's about it.
Old 04-24-2005, 12:09 PM
steck steck is offline
i ordered a door handle from GM,,,it actually wasnt that expensive. I painted it myself properly. and took it to garage...and they charged me an hour labour to replace it. total : around $125.00 Canadian.
