Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-20-2005, 03:26 AM
jonnysos11 jonnysos11 is offline
valves??
so i got my engine together i go through the steps of timming it i make sure im at tdc, and my cam is in up position, my dizzy is fireing on the first cylinder i get the car started did not sound good. a few friends say "my pistons hit the valves if i had a really off timming on it"...any info on this one????thanks
Old 01-20-2005, 01:34 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: valves??
mnaually put you car back to tdc and see if the marks line up
Team Lonely Drivers
Old 01-20-2005, 08:35 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: valves??
Your friends are right to an extent...if your timing was off a lot then the exhaust valves would smack the top of the piston, but if it was off only by one cog on the top timing gear then it will just run like crap. When you put the timing chain on the two gears, did you make sure that the slack was out of the chain and that all of the timing marks lined up??
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
