Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 01-20-2005, 02:56 AM
BurtMuston BurtMuston is offline
Pls Help 99 runner dash lights
I have a 99 4runner with a dealer installed toyota security system. The other day, I used my remote to unlock the truck, and I noticed that the flashers did not flash, but I still get the beep. When it got dark out, I noticed that the dash lights are now inoperative. I have checked all fuses and they seem fine, I have played with the dimmer adjustment to no avail, and no other lights are out in the vehicle inside or out. The signal lights still work, but not to indicate when the keyless entry is used.
I would really appreciate it if someone could shed some light on this irritating problem. I'm sure that its something stupid but I for now I am stumped.
Thanks in advance, Burt
Old 01-20-2005, 01:37 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Pls Help 99 runner dash lights
Check TAIL fuse
Check Tailight control relay
Check your dimmer rheostat for function
Old 01-22-2005, 02:04 PM
Thanks, now fuse shorting out
Thank you. I didn't figure the tailight fuse would be linked to the dash but it is the one that is burnt out. I'll have to find the short 'cause when I replace it it just burns out instantly. Could this be the control relay?
Any help is apreciated.
Old 01-22-2005, 03:14 PM
Brian R.'s Avatar
Resident Chemist
Any part of the circuit could be the cause of the short, including the relay and dimmer.
