Old 01-19-2005, 10:12 PM
troy1 troy1 is offline
AF -Advisor
mass air flow sensor
Any one know how to test a mass air flow sensor on a 95 3100
Old 01-19-2005, 10:34 PM
cadgear's Avatar
cadgear cadgear is offline
Re: mass air flow sensor
If you suspect a bad one, give it a whack when the engine's running. Scan tool is another way, and there's a third way to check with a DVMM but I have no idea what it is.
Old 01-19-2005, 10:36 PM
luminator96 luminator96 is offline
Not sure if it would be good for the engine, but cloag the air intake with something, engine should run rough because of lack of air, which should trip the mass air flow sensor.
Old 01-20-2005, 05:58 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Re: mass air flow sensor
That's all I ever did. Just tap it sharply with a screwdriver handle while it's idling. If it's bad, the idle will break up or possibly even die.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
