Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 03-12-2002, 02:46 AM
CRX586's Avatar
CRX586 CRX586 is offline
Single or Dual Carb
I'm still trying to figure out which engine I have... the serial reads D15B (no number after that). There is no mention of VTEC on the engine...
I know that its SOHC and 16v. How can I determine if its single or dual carb....
"the D15B came in both single and double carb'ed SOHC versions, the dual-carb version delivering as high as 105ps in the CRX 15X"
FROM http://asia.vtec.net/article/d15b/
Anyone know where this engine came from (car/country). Doesn't seem like they were sold in the US market, I could be wrong...
Old 03-12-2002, 05:25 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Look and see how many carburettors are on it :finger:
We got the D15B twin-carb here - it has twin keihin carbs on it (both single barrel carbs). It was rated at 98bhp down 7bhp on the JDM spec engine. The carbs will be facing back towards your firewall and there will be a black, oval airfilter box with them parallel to the firewall. Single cam engines had the air filter box on top I think (they did on our 3G Civics anyway). The civic also had a 4-2-1 exhaust and a different cam profile apparently.
We only got this engine in our Civics - our CRXs "only" had the ZC as it's engine.
Hope the info helps.
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 03-12-2002, 05:52 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
CRX586 What you've found is the specs for the JDM 15x CRX, or the almost base model 2g CRX.
If whats printed under your name is correct you have a USDM CRX Si, in which case its not carberated, but Fuel Injected.
Old 03-12-2002, 05:03 PM
CRX586's Avatar
If whats printed under your name is correct you have a USDM CRX Si...
Ok... for now my profile has been updated since I don't really know what engine I have... the car is originally an HF - put in a SI engine a few years ago, or at least that's what I thought they did, but apparently not! I've learned a lot since then...
So I'm running an ECU from an US SI on my D15B with who-knows what tranny. CRAP. Just get me a b16a already.
I'll check the carbs when I get home (out of curiousity).
Old 03-12-2002, 06:16 PM
Moppie's Avatar
Master Connector
Well as far as I know there was no Carberated 2g CRX sold in the US.
(maybe a base base model??)
And if you have an Si engine then its deffinitly not Carb'd.
And If your running an ECU, then its most deffintly not Carberated.
(altough the Carb'd cars did run a small ECU for ignition advance (dont ask why)
What you should be looking for is the injection set up. Find if its multi point, or Programed Fuel injection.
Easy to tell, as it should be printed on the inlet manifold.
OR just look for the Fuel injectors, the P-FMI has 4 and the Mulitpoint only has 2.
Also take a look at the frount of your engine. On the left hand side right where the g/box bolts up is a small flat area. Clean any crap of it, and staring you in the face will be the engine code.
It should read D16y something.
Old 03-13-2002, 05:46 AM
EF6_CR-X's Avatar
EF6_CR-X EF6_CR-X is offline
My Dual Carb CRX is wired up like a christmas tree, it sure has an ECU. The whole thing is 'dynamic' it has an oxygen sensor, EACV, and auto mixture control, and a whole heap of other sensors and too many vacum lines to count, the carbs are soo friggen complicated, it may as well be injected really.
But in saying that, if you pull the ECU fuse out it still goes
The ECU is basically for emissions control.
Old 03-13-2002, 06:32 AM
EF6_CR-X's Avatar
To be honest I don't see why someone would go to the effort of importing the dual carb D15B engine as it has very similar performance specs as the US Si.
Here is a pic of my engine bay in my CRX
Old 03-13-2002, 06:45 AM
Setanta's Avatar
I don't think anyone was suggesting it
I miss the twin-carb though - the car was fun... but it was going to get ZC'd anyway Now I don't care one way or another
'99 PY DC2R
'85 BBS BMW E30
Old 03-13-2002, 06:46 AM
SkyNex721's Avatar
SkyNex721 SkyNex721 is offline
Send a message via AIM to SkyNex721
There were no carberated 2g CRX's in the US.
Si - MPFI
Dx -DPFI
Hf - MPFI
All of them were Programmed Fuel Injection
Multiport had 4 injectors and the Dualport had 2 injectors.
R.I.P. - You shall be resurrected.
Old 03-13-2002, 11:35 PM
Moppie's Avatar
Master Connector
Its just like an Alfa im putting back together at work at the moment.
It has an ECU, but it dosnt do much. Mostly just runs the timing advance, and some environmental fuel controls.
If you trace most of those vacum lines very few of them actualy go any where. They tend to be things like idle speed step up controlers, and cold idle controlers, etc etc etc. All of which are run of engine temp, and vacum pressure. And have no input from the ECU.
But your right about it being complicated, Iv pulled the head off an 88 prelude, which is far worse. It took as long to reconnect all the vacum lines as it did to bolt the head back down, and bolt the carbs and exhaust back on. (forunatly most are moulded into a spefic shape and lenght, so have limited placed they can go)
Old 03-14-2002, 12:20 AM
Setanta's Avatar
looks like we got a simplified version - but it was the approx 100bhp version. No ECU, little in the way of wiring and the engine bay wasn't as cluttered as the CRX in that pic. Then again - ours wasn't JDM - it was built in Japan for the Aussie market
'99 PY DC2R
'85 BBS BMW E30
Old 03-15-2002, 01:17 PM
CRX586's Avatar
My Engine Pics
Old 03-15-2002, 01:21 PM
CRX586's Avatar
1. The car is originally an HF, which means is had MPFI (still there). I did the swap about 2 years ago thinking that I was getting a US Si engine.
2. The engine code reads D15B. No number after that.
3. I switched out the original ECU for one from an SI. This moved the redline up and might have improved acceleration.
I just want to know what the stats are for this engine. Is it possible to have a non-carb D15B? Did any US cars come with this engine??
Thanks for the help!
Old 03-15-2002, 06:12 PM
CRX586's Avatar
Damn, why aren't those photos showing up???
Old 03-15-2002, 06:14 PM
CRX586's Avatar
http://www.geocities.com/clone586x58...es/Engine2.jpg
http://www.geocities.com/clone586x58...es/Engine1.jpg
