Old 01-19-2005, 06:10 PM
713juggalo 713juggalo is offline
engine reving up by it's self
i have a 88 honda civic hatchback. sometimes it starts to rev up by itself. without me even touching the gas. it doesn't do it all the time. but when it does if i turn my car off it will not start for awhile. i'll try to start it but it it will not. then i smell gas. i had a complete tune up before i drove down to texas from oregon. also what is the ecu. what is this code stuff i've been reading about? do i have the light that blinks under the carpet on the pass side floor board. thanks to any info ya'll can give. i don't really know to much about cars.
Old 01-19-2005, 06:21 PM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: engine reving up by it's self
probably a vaccum leak or you throttle body is sticking open try spraying some carb cleaner on inside the throttle body break the buildup loose
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 01-19-2005, 06:39 PM
devaney devaney is offline
Could the revving be the tranny? I'm not sure on that one.
As for the car not starting for a while that could possibly be the main relay. It's a common problem especially when the car is hot.
I don't know a lot about the ecu but I'll try to explain what I think it is. ;-) The ECU is the engine control unit. It's a computer in your car that helps manage the car's functions like your coolant temp and fuel injectors and it reads all the different sensors in your car. It's reading tons of data all the time. Looking at the ECU in your car can tell you what's wrong with it, try reading the "4th Gen FAQ - If you are new, please read before posting" threads. Post # 5 tells u what what the codes are. You'll have to look under the passenger carpet and see how many flashes it has.
Hope I helped a little! If you do a search on the board I think there's more posts about how to read the ecu codes.
Old 01-19-2005, 09:28 PM
i don't think it is the tranny. it's a 4 speed maunual. the check engine light comes on everytime i drive. do all 88-91 honda civic have the ecu light thing under the pass floorboard?
Old 01-20-2005, 02:43 AM
honduhcivic honduhcivic is offline
definetly not the tranny, thats the dumbest thing i've ever heard.
How high does it rev? Does it rev up and down and up and down, or does it just rev high and stay there?
Anti-rice leader #001
I <3 my b16
Old 01-20-2005, 04:21 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
hey be nice, just because he's not right doesn't mean its the dumbest thing ever - leave those comments to urself
does sound like a vaccum leak, and the ecu is definitely throwing some codes
maybe the engine gets flooded with gas? dont know if that only happens on carbed engines..
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 01-20-2005, 04:54 PM
Gohan Ryu Gohan Ryu is offline
Re: Re: engine reving up by it's self
He might not have been nice, but he was honest. Whoever heard of a tranny revving up by itself? Not the dumbest thing, but one of the dumbest things I've ever heard.
No offense, but if you don't have any clue, don't make something up. At least his next two paragraphs were "somewhat" helpful.
Old 01-20-2005, 04:55 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
agreed, ur just a noob here, dont think u can come in acting all high and mighty because u post on honda tech too, give a little respect and u'll get it back
and for the reving, possible vaccum leak, could be the electronic air control valve, or stuck throttle body, for the no start, that might be ur main relay
Good Luck
Old 01-20-2005, 05:39 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
watch it end up being his tranny for some ungodly reason.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 01-20-2005, 06:00 PM
ef9er ef9er is offline
Send a message via Yahoo to ef9er
this happen to my friend with his b16 turbo and it blow the rings. it was the idle control valve. might be the same on your, but that is what his car did too
Old 01-20-2005, 06:02 PM
i looked at the ecu code and got code 1, 5, and 16. i now 1 and 16 what is 5?
Old 01-20-2005, 06:33 PM
map
Old 01-20-2005, 08:00 PM
it's all good. the only thing i'll correct is that i'm not a he.
my hubby had a camaro once (an automatic) and when the tranny started to go, it started trying to go into higher gears by itself so i took a stab in the dark and guessed the tranny.
sorry!
Old 01-20-2005, 10:34 PM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
when the tranny in my probe died it would shift at random and if i gave it alot of gas it would upshift and downshift over and over really quickly and kinda buck.
1991 Honda Civic DX Sedan
Old 01-20-2005, 10:35 PM
1PhatCX's Avatar
ur cars possessed hehe
