Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-19-2005, 03:55 PM
londa hover londa hover is offline
installing lsd??
i ordered an obx lsd for my gsr tranny. how hard is it to install? is it something i can do myself? and if not whats a reasonable price for having a shop do it?
Old 01-19-2005, 04:01 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Re: installing lsd??
What has been the most indepth project you have tackled on your car? For example what mechanically have you done, the most indepth or hardest. ie: changing spark plugs, changing oil, pulling the head off, rebuilding the motor, etc etc.
Old 01-19-2005, 04:28 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
just curious, where did get your OBX for the GSR tranny?? cuz the only ones ive found are for the LS tranny, or am i an idiot and are they interchangable?
Old 01-19-2005, 05:06 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
exactly what i was gonna ask green. i didnt think they had come out with the gsr lsd yet.
from what i hear the gsr trans lsd install is different than regular ls or b16 trans lsd install. its harder.
Team Lonely Drivers
Old 01-19-2005, 07:03 PM
Re: Re: installing lsd??
I once installed some gas in my gas tank. And once i jacked up my car, then put jack stands under to keep it from falling. j/k
But seriously, rebuilding the motor, taking it completley apart to put new pistons&rods in, needed a little help w/ the head&tranny though, but if i were to do it again, i could do it by myself, might need someone on the side to ask a question here and there.
Old 01-19-2005, 08:22 PM
whtteg's Avatar
Re: Re: Re: installing lsd??
Then I think you could probably handle it then. I myself have not installed a LSD but I have taken many of trannies out and that will more than likely be the hardest part of the whole project.
Try looking at this article, it might help out.
http://tech.hybridgarage.com/tech/lsd/index.html
Old 01-21-2005, 12:34 PM
Jeff C's Avatar
Jeff C Jeff C is offline
I have installed several lsds and the hardest part for most people is getting the tranny case off. After that, you will have to remove all the internals and then you can remove the differential. As far a installing it, finding the corrrect shim was a little PITA.
-1989 Honda CRX Si, B18A Pic FOR SALE
-1998 Honda Accord EX Sedan 5spd
-1981 Chevrolet Silverado, shaved and bagged Pic
Old 01-21-2005, 07:25 PM
yeah finding the right shim looked like the hardest part.
also remember how you took everything off
Team Lonely Drivers
Old 01-21-2005, 08:42 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
All i have to say is take your time labeling...it will save your ass some day. I rebuilt an engine with a buddy of mine and he didn't label and ended up forgetting the little metal gasket between the block and tranny and we had to strip the engine down and pull it...again. LABEL!! Do it for me.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 01-22-2005, 11:58 AM
whtteg's Avatar
Do you have a Helms manual? If not I will scan all the pages from the tranny section and post them up for you to print off or just look at. That way you will have something to look at if you get lost.
