Old 01-19-2005, 03:36 PM
Boosted1 Boosted1 is offline
I'm so proud of me!
I finally decided to stop talking about it, and actually order a boost controller. Mind you, I only got a MBC, but still, going from 9psi to 14.5psi. If the 1st gens make 300hp at 9psi, and the 2nd gens make 320hp at 11psi, then the gain for each additional psi is 10hp. The difference between 9psi and 14.5psi is 5.5psi. Using that same logic, I should gain 55hp. Does that sound reasonable? I am also going to get a downpipe, am looking for a good intake, and thinking about trying to gut my pre-cats (I'm not that handy). I need opinions though. I am going to find a boost gauge (probably just AutoGauge or something), but I want at least 2 gauges on my pillar. What other 1 or 2 gauges should I look at? There is an Air/Fuel gauge, just wondering what will give me good information while looking good. A trio of gauges would look pretty spiffy. What kind of gauges do you guys have or know of?
Ryan
1993 Mitsubishi 3000GT VR4 (STOCK)
1989 5.0L Ford Mustang (MODIFIED)
http://www.cardomain.com/memberpage/761789
Old 01-19-2005, 03:56 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Don't go straight to the 14.5 psi right off the bat. Work your way up and pay close attention to how your turbos behave. The 14.5 on the stock fuel system is good if everything is in tip top working order.
Resistance Is Futile (If < 1ohm)
Old 01-19-2005, 04:00 PM
Re: I'm so proud of me!
Could you recommend a good place to start? Possibly 11psi?
Old 01-19-2005, 04:17 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
sounds good
Old 01-19-2005, 11:10 PM
Hotshot8792 Hotshot8792 is offline
Re: Re: I'm so proud of me!
just do the free boost mod first which will automatically put you up to 2nd gen boost levels, then install the boost controller.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 01-20-2005, 08:51 AM
Anyone on the gauges?
Old 01-20-2005, 09:27 AM
Igovert500's Avatar
blue + red light magnet
Well, to start with the obvious, make sure you choose between a 0-20psi and a 0-30psi, based on your future plans. Also make sure your gauge shows boost and vacuum pressure(mine doesn't and it sucks!)
I got my A-pillar pod from www.importpoweronline.com
and my gauge at www.summitracing.com
(unless I confused the two)
The single gauge pod cost me like $25 shipped, it was gaugeworks brand. That is the cheapest I found, they can get more expensive if you go with Autometer or something.
I got the plainest black cockpit analog series VDO boost gauge for under $30.
Here are the replies people gave me when I asked the same questions awhile back:
http://www.automotiveforums.com/vbul...ht=boost+guage
http://www.automotiveforums.com/vbul...d.php?t=249976
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 01-20-2005, 11:37 AM
Hey thanks a ton, that helps alot!!
