Old 01-19-2005, 02:27 PM
thetruth4130 thetruth4130 is offline
need brakes in front
what tools will I need, 94 metro hatch 1.0 liter
i plan on getting new rotors and pads, thanks
Old 01-19-2005, 03:15 PM
crazyinkc crazyinkc is offline
Re: need brakes in front
You will need a 12 mm wrench for the caliper but the rotor replacement requires a socket for the axle nut, a sldehammer, and a 12 mm socket and rachet. You must remove the hub since the rotor is bolted to it on the back side. You will see what I mean when you pull the wheel (I assume you know you need a lug wrench too ). If the rotors have good thickness and are not warped, I usually rough up the surface with some 40 grit to clean off the glaze and stick a set of pads on and go. You can usually rent the slide hammer from you auto parts store.
