Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-19-2005, 02:00 PM
mcdaddy5 mcdaddy5 is offline
all power cuts off
All
I just brought and fixed a 94 talon auto, non turbo, 2.0L (timing and bent valves) I'm really happy. I 'm stumped now. the car ran great, no vibration, timing set good, good oil flow...everything.
I took it out for a test drive a few days on close trips around the block and one night with the lights, and heat on and maybe the radio, I got to the stop sign And everything went black, no lights no nothing. I turned everytihing off, put the car in park, and all the lights start dimming up. the car starts back up no problem and I drive back home. what's up I thought? Alternater...right
I pulled the alt. last night and got it tested at Oreilly. test comes out fine between 12 - 15 volts.
NOW what. any Ideas
thanks in advance
by the way the battery is new too
madaddy
Old 01-19-2005, 02:30 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: all power cuts off
You probably blew your alternater fuse... Look under the hood and see if you can find it. If that wasnt it post up again and let us know.
Old 01-20-2005, 07:07 AM
Question
I found 2 fuses, 1 was the reg. type which was fine. the other a black cube type, I pulled it and looked it over. How do you check that?
I talked to a friend last night. The alternator is wet around the casing. when replacing the Tb and Valves. I loosened the Power steering and fluid spilled on the alt. Could that fluid have got into the alt and now causing a "dead spot" from within. Anyboy got alternater rebuild experience? I might try and open it up tonight and take a gander
thanks for the quick response!
Old 01-24-2005, 11:46 AM
Talking Re: all power cuts off (SOLVED)
[with GOD all things are possible]
Problem SOLVED!!!!
I found a ground wire routed from the radio the the rear of the car. The wire got tangled in the track of the seat and bare wire was touching metal, in return causeing a short.
