Old 01-19-2005, 01:39 PM
indebt94 indebt94 is offline
cold startup
when it is really cold as it is now in delaware my 90 b16a hatch will start right up and then immediatley stalls out. it does this about five times before it finally stays running. it even still stalls when i give it gas. i would rather not burn my starter so does anyone know why this is happening. if so how is this solved.
Old 01-19-2005, 02:37 PM
travagliante's Avatar
travagliante travagliante is offline
Re: cold startup
hmm my integra has bad starts also. try giving it some gas after you start on it. If i dont do that with my teg it will die but after you give it a little gas it runs fine? hmm weird!
Old 01-19-2005, 02:42 PM
when i give it gas it starts to rev but still dies
Old 01-19-2005, 02:45 PM
Re: cold startup
hmmm so it only does it when its real cold? hmm
Old 01-19-2005, 03:33 PM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
Re: cold startup
check fuel pump to make sure it's working properly - maybe if it's real cold outside it won't wanna go and you're car will die out
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 01-19-2005, 03:35 PM
D16z6-T D16z6-T is offline
Banned
Re: cold startup
chech the vaccume lines and also it could be gettin fuel cut off somewhere to test if its gettin gas have someoen pull you in their car and u put it in second gear and then pop the cluch when it starts running push the gas and see if it goes if it dont and boggs out then ur not getting any gas.
