Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-19-2005, 11:03 AM
mrsyeltzin's Avatar
mrsyeltzin mrsyeltzin is offline
Starting problem
Im having a problem starting my 92 accord when its really cold out. The past few days its been hovering around zero when i go to start it, and its giving me hell! i have to turn the key 3-4 times before the engine starts. It seems like it wants to, but the first few times itll crank a bit, then shudder and stop. Im wondering, since the starter sounds slower when its cold, could it be that? Or is it something with the fuel? Plugs are relatively new, wires are in good shape, and the car runs absolutely fine once its running and warm. any help would be great.
proud accord owner
Old 01-19-2005, 12:27 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Starting problem
i had a problem like this before till one day it just wouldnt start. turned out it was my ignition coil.
chekc your spark and see if its weak or strong
Team Lonely Drivers
Old 01-19-2005, 01:07 PM
mrsyeltzin's Avatar
that sucks...thanks for the info. By the way, were there any problems when it was warm? i have trouble sometimes when its warm out it takes usually two times, but its a strong crank (i think this is related to the fuel filter that hasnt been changed in years).
proud accord owner
Old 01-19-2005, 03:35 PM
mrsyeltzin's Avatar
Re: Re: Starting problem
Originally Posted by hondance
could be just some electrical problem on your sensors like ECT, IAT, etc..check the wiring connections.
and it would act up like that just in cold weather?
proud accord owner
Old 01-19-2005, 04:26 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
well, your starter turning your engine over slower in the cold is due to you battery not having enough "cold cranking amps", this is fixed by buying a new battery with more CCA's then you currently have, you should find this printed on the a sticker that should be on your battery. as far as the car sputtering and stalling when its cold..... crap, i forget the name of the sensor.... but its the sensor that revs your motor a bit to warm it up quicker and when it gets warm it kicks the engine back to normal idle RPM...
Old 01-19-2005, 05:03 PM
with my car i had a hard time starting it cold but when warm it was no problem
Team Lonely Drivers
Old 01-19-2005, 07:44 PM
mrsyeltzin's Avatar
well i just bought a new battery...i thought i bought a good one but then again i really just looked at price. Anyway, that sensor info is good to know but it doesnt have a problem like that becuase once it starts up it revs up to around 22-2500 for a while, so that works. Ill check the CCA on my battery. Anyone have any recommendations on how many CCA's i should have when its 0 degrees? thanks
proud accord owner
Old 01-19-2005, 07:46 PM
Kind of a Big Deal
the more the merrier... just ask for the battery with the most CCA's that fit in your car.
Old 01-20-2005, 10:37 AM
mrsyeltzin's Avatar
maybe ill just put a hand warmer on my battery before i start my car???? j/k
proud accord owner
Old 01-20-2005, 12:15 PM
Kind of a Big Deal
lol or many.... they actually do make a battery blanket for just this problem....lol, its supposed to hold the heat in better.
