Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-19-2005, 10:15 AM
unknownluder69 unknownluder69 is offline
is this all I need for a working turbo?
I found a kit that i customized and this is what it comes with.This turbo kit includes a turbo header, a wastegate (either internal or external), a turbo, and an intercooler. All this for like $1500. is this a good deal or am i getting ripped off b/c i still need other parts that I would have to buy seperatly. all feedback is appreciated.
Old 01-19-2005, 12:43 PM
Ziggymidget5 Ziggymidget5 is offline
Send a message via AIM to Ziggymidget5
Re: is this all I need for a working turbo?
I'm no turbo expert, but I'm pretty sure no. You'll need a BOV, an intake or just the filter, some sort of engine management, possibly injectors (prolly not for low boost), and piping if it's not included, and just various tubes and such. Other people have more knowledge than me though.
White 1995 Prelude Si 5-speed 107,000 miles
AEM CAI
AEM Pulleys
DC Sports CC Header
Carsound Hi-flow Cat
5Zigen Fireball Cat-back
17" wheels with 215/40/17 tires
Custom paint on some interior (yellow)
Currently in Progress:
KMS (Honda-performance.com) Camshafts, Valve springs, and Retainers
Skunk2 adjustable cam gears
Wish me luck on this project, something always seems to go wrong.
My 1995 Prelude Si
Old 01-19-2005, 02:11 PM
the kit i looked at buying included an exteernal bov (35mm) and the piping for the exhaust system i.e. downpipe and a custom 3" exhaust system was going to be bought seperatly. I mean was there any thing major that i have not included that i would for sure need. To start off im goin to run around 5-7 psi of boost. I was goin to get a gauge pod for the side part of my window, and a computer system setup for managment. but that is for a different forum.
Old 01-20-2005, 04:17 PM
5gcivic's Avatar
5gcivic 5gcivic is offline
Re: Re: is this all I need for a working turbo?
That is a external wastegate, not bov. The bov goes on the intake piping after your intercooler but before your throttle body. Youll need to get an adjustable fuel pressure regulator, an fmu and all the piping and connections for the intake. You will also want to retard your timing from -3 to -5 degrees. I also suggest purchasing a VAFC that way you can tune when your vtec engages and how long the injectors stay open so you dont run too lean. Its always better to run to rich then lean and tune from there.
Old 01-21-2005, 12:53 PM
AcesHigh's Avatar
AcesHigh AcesHigh is offline
Prelude Guy
Send a message via AIM to AcesHigh
You don't necessarily need a bypass valve altogether..
You will need mundane things like oil lines, and as mentioned above, you will need to do something to the fuel system.
1993 Mazda Rx-7 Touring
Ricer Extraordinaire
Old 01-21-2005, 01:05 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
not needed, but HIGHLY recommended is a Turbo timer, otherwise u shorten the life of your turbo a lot.
Old 01-21-2005, 03:32 PM
so how much more m i looking at spending on this other stuff? i mean if it will cost around a grand i might just go and buy a whole kit for around3 grand instead.
Old 01-21-2005, 03:41 PM
Kind of a Big Deal
Id just buy a kit, that way u dont forget anything.
