Old 01-19-2005, 10:20 AM
KTem's Avatar
KTem KTem is offline
A few questions
Hi,
First of all, I'm new here, so let me introduce myself.
I'm Koen, from Netherlands.
I'm not experienced at car modeling; usually I only build tanks, but now I wanted to try something different so I got myself the Tamiya Supra.
I have a few questions regarding the Supra;
1. Should I use primer, and if yes, why should I use it?
2. Should I apply one layer of paint, or multiple layers?
3. Where can I find a marker that is thin enough to paint the body lines, so that they look sharper?
4. I normally just paint with a brush, but as for Supra I've bought a spraycan.
Should I just spray around, or is there some kind of special technique to do it?
Oh, yes, and by the way; you've got some great models around here.
Awesome!
Old 01-19-2005, 10:29 AM
Vric's Avatar
Vric Vric is offline
Re: A few questions
Originally Posted by KTem
Hi,
Welcome on the forum. You really should read the FAQ where many of your question is answered.
1. FAQ
2. FAQ
3. There is some marker Called Gundam Marker. this is the best way.
4. FAQ & Tamiya How To
Old 01-19-2005, 10:31 AM
Dr.AK's Avatar
Dr.AK Dr.AK is offline
1. Yes, you should. It prepares the plastic so the paint will stick better on it. And if the body of the car is molded in color it can shine trough some colors.
2.You should definitely add multiple layers of paint. It will give a much smoother finish.
3. I'm sorry, I don't know about that.
4. Try this: http://www.italianhorses.net/Tutoria...aint/paint.htm Also, you shouldn't spray on one spot continously , so keep the can moving.
Old 01-19-2005, 12:56 PM
KTem's Avatar
Okay, thanks a lot!
I'll buy some Tamiya primer tomorrow, and when I'm done I'll make pictures of it and post 'em here
Old 01-19-2005, 02:00 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: A few questions
3) Go to an art supply store and look for Micron pens. They come in uber-thin widths, down to 0.20mm, and are probably what Gundam Markers with different labels. Michael's crafts has them.
I'm not sure which width to get, but those will work.
Old 01-19-2005, 02:06 PM
Vric's Avatar
Re: Re: A few questions
Gundam marker are paint, while those in art store are Ink. I tried, and it's a pain to work with ink (don't flow correcly on gloss surface, take days to dry, never even think to put a clear coat over it) they are also more expensive.
Old 01-19-2005, 02:29 PM
Re: A few questions
I see. Live and learn, thanks for the info.
