Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 01-19-2005, 08:53 AM
Gerrick Gerrick is offline
98 Won't start!! Put new starter already!
PLEEEZ give me some advice. I put a thread already and noone responded.
See:
http://www.automotiveforums.com/vbul...d.php?t=350144
(Put new starter, ignition coils, sparkplug wireset....and it won't start!
Old 02-09-2005, 11:30 AM
Basstour Basstour is offline
Thumbs up
Sounds to me like you ain't getting enough current to the starter. As your batt is fine I would hazard a guess that it is a poor connection at one of three places, ether the batt terminals (Disconnect and clean), your earth connection to the block (Disconnect and clean) or the large power wire to the starter. Once again you guessed it DISCONNECT AND CLEAN. Forget about the coil/wireset, it has no effect on the starter’s ability to crank the motor over.
Let us know how you go... I'd be surprised if this doesn't fix your issue.
Old 02-09-2005, 01:58 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 98 Won't start!! Put new starter already!
Looks to me like there were a lot of responses in that other thread.
Old 02-09-2005, 08:28 PM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
Responses all over!
Looks like at 41 posts in response to your original thread.
Counting the link that Brian pointed to.
Here read this one:
http://www.automotiveforums.com/vbu...ad.php?t=350144
Look FORGET everything else! KEEP IT SIMPLE! You should only be concerned with the starting circuit. Get it to where it will turn over consistantly THEN worry about the GD secondary ignition parts.
Worry this:
BATTERY
Starter cables (high current)
STARTER (includes selenoid, contacts, mechanical travel)
Remember this, most of the help that is offered here is offered up by individuals that, if they had your rig at their fingertips could have it running befur lunch. Help them help you.
Good Luck
Old 02-09-2005, 08:54 PM
Cd's90 Cd's90 is offline
Assuming this turns over with a wrench on the Crank Bolt.
Old 02-09-2005, 08:59 PM
4Wheel's Avatar
AF - Advisor
Re: Re: 98 Won't start!! Put new starter already!
OMG! I just assumed it would still!
The first thread stated it was turning over BUT..........
The cables would be getting pretty warm!
Pull the plugs run compression tests etc...
