Old 01-19-2005, 06:37 AM
volkerc's Avatar
volkerc volkerc is offline
Question '91 PA - PCV valve,where is it?
Could anybody tell me where the Pcv valve is located on a 91 PA, not ultra? And how does it look like?
Old 01-19-2005, 11:22 AM
rotaran's Avatar
rotaran rotaran is offline
Send a message via MSN to rotaran Send a message via Yahoo to rotaran Send a message via Skype™ to rotaran
Hi Volker.
Unter der Plastikabdeckung vom Motorblock. Ist ein kleiner silberner Zylinder. Bild folgt.
Gruß Michael
1991 Buick Park Avenue
1995 Ford Fiesta
Waghaeusel/Germany
Old 01-19-2005, 01:56 PM
deadring deadring is offline
Re: '91 PA - PCV valve,where is it?
no deutsch sprechen im das forum bitter :P
wow am i ever rusty... heheh
Deadring
Old 01-19-2005, 05:01 PM
volkerc's Avatar
Talking Re: Re: '91 PA - PCV valve,where is it?
Deadring
That does not answer my question or help me find the Pcv valve, Deadring...
Old 01-19-2005, 06:31 PM
BIG-L's Avatar
BIG-L BIG-L is offline
Here are some instructions for a newer 3.8,but it might help Click Here
ClubGP Member 6530
Since 2001
Old 01-20-2005, 04:00 AM
rotaran's Avatar
1. Remove the decorative cover from around the intake plenum. The PCV valve is located under the flat area of the cover behind the steering pump.
2. Remove the bolts that fasten the cover plate to the intake manifold. Be careful as you loosen the cover because there is spring tension underneath!
3. Remove the cover from the intake manifold.
4. Remove the spring and PCV valve from its cavity.
5. Clean or replace the valve and spring as required.
Mike
1995 Ford Fiesta
Waghaeusel/Germany
Old 01-20-2005, 05:46 AM
volkerc's Avatar
Mike
Thank you for your advice. I must say though that the cover is already missing, sad to say. But now I know where exactly to look.
Thanks again.
Old 01-24-2005, 06:35 PM
swipter swipter is offline
The complete kit at the Buick dealer is $22. This includes a new cap, spring, gaskets and PCV valve.
Old 01-25-2005, 05:33 PM
volkerc's Avatar
Smile Re: '91 PA - PCV valve,where is it?
Thanks swipter,
thanks to all the help of everybody that listed here I was able to locate and change the valve. Looked like I expected, previous owners never changed it, because it is so well hidden. And yes I had the plate that was secured by bolts.
Old 01-29-2005, 10:20 AM
auto trainy auto trainy is offline
Thank's BIG-L that's the best way to explain where and how to replace a PVC valve on a 3.8 I've ever come across.
